Squatch25
Sean
Englewood, fl
2025 4runner Offroad Premium
For those interested here's my rear storage / pullout build so far. I chose lightweight aluminum extrusion vs wood and extremely happy with how it's turning out and farrrrr lighter than wood. Input and opinions welcomed.
2025 2026 4runner 6th gen Rear cargo storage / pullout drawer DIY build (updated with photos of framework and mounting hardware) 1000024528
2025 2026 4runner 6th gen Rear cargo storage / pullout drawer DIY build (updated with photos of framework and mounting hardware) 1000024529
2025 2026 4runner 6th gen Rear cargo storage / pullout drawer DIY build (updated with photos of framework and mounting hardware) 1000024531
2025 2026 4runner 6th gen Rear cargo storage / pullout drawer DIY build (updated with photos of framework and mounting hardware) 1000024565
2025 2026 4runner 6th gen Rear cargo storage / pullout drawer DIY build (updated with photos of framework and mounting hardware) 1000024584
2025 2026 4runner 6th gen Rear cargo storage / pullout drawer DIY build (updated with photos of framework and mounting hardware) 1000024585
2025 2026 4runner 6th gen Rear cargo storage / pullout drawer DIY build (updated with photos of framework and mounting hardware) 1000024586
2025 2026 4runner 6th gen Rear cargo storage / pullout drawer DIY build (updated with photos of framework and mounting hardware) 1000024587
2025 2026 4runner 6th gen Rear cargo storage / pullout drawer DIY build (updated with photos of framework and mounting hardware) 1000024588
2025 2026 4runner 6th gen Rear cargo storage / pullout drawer DIY build (updated with photos of framework and mounting hardware) 1000024589
2025 2026 4runner 6th gen Rear cargo storage / pullout drawer DIY build (updated with photos of framework and mounting hardware) 1000024590
2025 2026 4runner 6th gen Rear cargo storage / pullout drawer DIY build (updated with photos of framework and mounting hardware) 1000024592
2025 2026 4runner 6th gen Rear cargo storage / pullout drawer DIY build (updated with photos of framework and mounting hardware) 1000024593
fur_runner
Aaron
25 ORPH
Love it. How did you attach it to the floor/stop it from rocking with the slides out? What resources did you use for planning it out?
Squatch25
Squatch25
Sean
Englewood, fl
It's not attached yet as I need to remove it to finish the drawer side on the left. As for resources, I'm a hobbiest woodworker so basically envisioned it and made it happen. Not plans whatsoever. Got on Amazon and ordered the aluminum and brackets. Took some measurements, made some cuts, and watched it evolve lol.
Squatch25
Squatch25
Sean
Englewood, fl
Which brackets did you use, specifically for the slides?
The slide out is from Overland Vehicle Systems. Although the quality seems solid, they definitely lack in the customer service department. It's like pulling teeth to get them to answer the phone. That said I'd recommend the slide out.
C/G
Cary
Orange County, CA
Squatch25, love it. Great work. Does the bottom pullout when fully extended work as a cooktop? Where would the heat source come from?
Squatch25
Squatch25
Sean
Englewood, fl
The framework is custom built by myself out of aluminum extrusions from Amazon. You can use either 8020 or 2020 and then the appropriate brackets based on your design. As for the slide out that entire unit came from Overland Vehicle Systems. I attached that to the aluminum rails with tslot type nuts and bolts through the bottom mounting holes in the slide out box. They aren't as large as the typical mounting bolts that would be used with wood so I used a total of 8. Understand that this is still a work in progress so whether or not the smaller bolts will hold up is yet to be determined. Hopefully that helps. I can add some photos of the bolts etc later on as well.
Squatch25
Squatch25
Sean
Englewood, fl
Thank you. Yes if you look at pics 8 and 9 those show the cooktop part. I haven't purchased a grill yet but leaning towards one of the Blackstone grills. Either the 14" or 20"
Squatch25
Squatch25
Sean
Englewood, fl
A few of you wanted additional photos of the framework and mounting hardware. I had to take the frame out to do some tweaking for fitment so while do so I snapped a few more pics for y'all. Everything shown was found on Amazon. Drawer slides still haven't been delivered but once the drawer is built and installed I'll update again. I don't have a scale but lifting it and a 2x4 they are very close in weight so the aluminum 2020 is a huge weight saver for sure. Enjoy!
2025 2026 4runner 6th gen Rear cargo storage / pullout drawer DIY build (updated with photos of framework and mounting hardware) inbound8832139549992609512
2025 2026 4runner 6th gen Rear cargo storage / pullout drawer DIY build (updated with photos of framework and mounting hardware) inbound2493133453646796072
2025 2026 4runner 6th gen Rear cargo storage / pullout drawer DIY build (updated with photos of framework and mounting hardware) inbound5356328937182944465
2025 2026 4runner 6th gen Rear cargo storage / pullout drawer DIY build (updated with photos of framework and mounting hardware) inbound3752415330026423007
2025 2026 4runner 6th gen Rear cargo storage / pullout drawer DIY build (updated with photos of framework and mounting hardware) inbound2553299660322513293
2025 2026 4runner 6th gen Rear cargo storage / pullout drawer DIY build (updated with photos of framework and mounting hardware) inbound6635127185518709448
2025 2026 4runner 6th gen Rear cargo storage / pullout drawer DIY build (updated with photos of framework and mounting hardware) inbound4012687117461454040
2025 2026 4runner 6th gen Rear cargo storage / pullout drawer DIY build (updated with photos of framework and mounting hardware) inbound1013497327833986211
2025 2026 4runner 6th gen Rear cargo storage / pullout drawer DIY build (updated with photos of framework and mounting hardware) inbound199890853494304310
2025 2026 4runner 6th gen Rear cargo storage / pullout drawer DIY build (updated with photos of framework and mounting hardware) inbound8135498301556060998
Farzad_k
Farzad
Portland, Oregon, USA
6th Gen 4Runner TRD Off Road
Great work. Thank you for sharing. What length extrusions did you find to be most economical for your design?
Thanks
Farzad
Squatch25
Squatch25
Sean
Englewood, fl
I ordered 2 packs of 48" and 2 packs of 15" with very little leftover.
famrunner6g
2025 4Runner TRD Off Road Premium i-FORCE MAX
This is awesome work! Thank you! I'm still wondering how to secure a shelf to the hybrid floor. We have fridge and slider on the way.
