MUFASA
Paul
Bay Area
2025 Toyota 4Runner Trail Hunter and 1994 Toyota 4Runner SR5
Stock trailhunter, 35 x 12.5. Removed crash plates and no rubbing. Full stock setup, and wheels.
Looks tuff! What brand tires?
Ekko4r
Jesse
2025 4runner trailhunter
Do you have a before and after shot?
engineero
Justin
2025 4Runner Trailhunter, Jeep 392 Final Edition, Jeep Rubicon Xtreme Recon 2D
Looks great. Could you provide a few more pictures and details. Did you remove the mud Flaps also? Which tires did you use?
papadop88
2025 4Runner TRD Pro
Those are Baja Bosses...great tires. Just heavy.
papadop88
Curious, how's your MPG and ride quality with those tires? I'm actually considering them because they're a "D" load which is soft relative to an "E" load, but at 73lbs per tire, they're making me nervous...
Icculus
Adam
NC
2025 IC Trailhunter
Looks great. I'm very curious about the fitment though. I really like my Trailhunter wheels; however I've always been under the impression that for 35x12.5 you needed at least 8.5-9" wide wheels for a proper fit and the the 7.5" factory wheels were just too narrow.
papadop88
The TRD Pro wheels are 18x8.5. Aren’t the TH the same specs? They should be…
Btw, you can put a 35x12.50 on an 8” wheel with no issues.
papadop88
Simply the best tires I have ever had. I will never switch. Cant wait to put a set on the 4runner.
Agree. The Baja Boss AT is arguably the best tire you can buy. 3Peak snow rated, works exceptional in the rain and has aggressive sidebiters.
I think I'm getting over their weight for the 35 because they are D load, and I'm just gonna replace my Recons with them.
Icculus
Adam
NC
2025 IC Trailhunter
https://www.4runner6g.com/forum/thr...izes-widths-brands-2025-4runner-6th-gen.1962/
lists both the TRD Pro and the Trailhunter wheels as 7.5"
The ORP and Limited are listed as 8"
ETA: Scrolling through the thread it looks like the TRD Pro and Trailhunter may be 8.5" It seems like there is a discrepancy in the info avail and if indeed 8.5 then the original post needs to be updated to display correct info
papadop88
Kevinba47
kevin
Delaware
6th Gen TRD PRO
do you think i could fit a 35x12.50r/18 on my stock trd pro?
