If you have a snap-on scanner 2025 Toyota 4Runner diagnostic software is here.
Wagzilla
James
2025 4runner trd pro
I know some of you guys have snap on scanners and you’ve been waiting for the software release. It came out this morning.
2025 2026 4runner 6th gen If you have a snap-on scanner 2025 Toyota 4Runner diagnostic software is here. IMG_0607
2025 2026 4runner 6th gen If you have a snap-on scanner 2025 Toyota 4Runner diagnostic software is here. IMG_9874
2025 2026 4runner 6th gen If you have a snap-on scanner 2025 Toyota 4Runner diagnostic software is here. IMG_9876
2025 2026 4runner 6th gen If you have a snap-on scanner 2025 Toyota 4Runner diagnostic software is here. IMG_9877
2025 2026 4runner 6th gen If you have a snap-on scanner 2025 Toyota 4Runner diagnostic software is here. IMG_9875
2025 2026 4runner 6th gen If you have a snap-on scanner 2025 Toyota 4Runner diagnostic software is here. IMG_9878
2025 2026 4runner 6th gen If you have a snap-on scanner 2025 Toyota 4Runner diagnostic software is here. IMG_9879
Wagzilla
Wagzilla
James
Interesting if you look at the last picture, it talks about changing your oil and it says you could use 5W-20 however it tells you on your next oil change. You should go back to 0W 20.
AdFour
Washington
Interesting if you look at the last picture, it talks about changing your oil and it says you could use 5W-30 however it tells you on your next oil change. You should go back to 0W 20.
Where do you see 5w-30? It shows 5w-20 but says you must go back to 0w-20 on the next oil change. The owners manual says the exact same thing. Prob copied over from that.
Wagzilla
Wagzilla
James
thank you good catch fixed
