Iconic Fabrication Offroad
Devon
Kansas
2026 TRD ORP
Hey everyone, I wanted to introduce myself and my business, Iconic Fabrication Offroad.
I’m an engineer and Toyota 4x4 enthusiast, and I started Iconic Fabrication Offroad designing practical parts that solve problems I’ve run into myself. A big focus of the business has become transmission cooling. Transmission cooler kits are by far my best-selling products for the older-generation 4Runners, FJ Cruisers, and GXs.
I recently picked up a 2026 4Runner TRD Off-Road Premium, which I’m using for development and real-world testing of parts for the new generation.
One thing that immediately caught my attention is the factory transmission temperature gauge. It behaves more like a dummy gauge than a true temperature gauge, staying around the middle across a very broad temperature range. By the time it actually tells you the transmission is seriously hot, you’ve already reached temperatures you really don't want to see. The only way to check temperatures is using an OBD Bluetooth monitoring device.
Considering how many discussions there already are about transmission temperatures and transmission-related concerns on these new trucks, I think an auxiliary transmission cooler could end up being a very useful modification—particularly for towing, off-roading, hot weather, or anyone planning to keep their 4Runner for a long time.
I was the first to develop a transmission cooler kit for the new 4runner and the only company to publish actual results. Here is a link to the transmission cooler page which has alot of info about it including temperature graphs.
https://iconicfabricationoffroad.com/products/2025-4runner-transmission-cooler-kit
Feel free to ask me anything about the kits, transmission temperatures, testing, or the new 4Runner. I’m happy to share what I’ve learned.
-Devon
MARK4A3
Kitsap County, WA
26 4Runner ORP Hybrid
Does the ORP hybrid come with a transmission cooler when optioned with the brake controller?
Devon
Kansas
2026 TRD ORP
Short answer is no. The long answer is the new 4runners come with one of three configurations for "transmission coolers" from the factory. None of them are equivalent to the old style "tow package" aux cooler or aftermarket aux coolers. Toyota equips the new trucks with either:
1) A standard in radiator tiny cooler
2) A standard in radiator tiny cooler with a thermostat on side of transmission
3) A standard in radiator tiny cooler with a small sandwich cooler. (my TRD OR has this)
See attached pdf file for pictorial diagrams.
MARK4A3
Kitsap County, WA
So your kit will take these existing lines, then extend them to a new bigger cooler? Will the front end need to come off to install this?
Devon
Kansas
2026 TRD ORP
Yes the front bumper/grill assembly needs to be removed. Once you know how to do it it's really not that bad. I have a video linked on the cooler product page on my website on how to remove this. It's just alot of the same size bolts and push pins.
There are hardlines coming from the transmission and stop beside the motor. You just have to remove one of the short rubber hoses and replace it with a hose going to and from the new cooler. Each hose is only about 3 feet long and easy to access. The kits include the extra hose.
It's most recommended to run the fluid through the existing tiny coolers and the secondarily through the new aux cooler, then back to the trans.
AJAugust
Alan
Sturgeon Bay, WI
2016 Subaru Outback 3.6R
I’m at review stage of selecting my next new vehicle. The 4Runner Platinum is high on my short list. I’m looking forward to owning one, likely a 2027 model. I will definitely keep this add on transmission oil cooler in mind.
Daniel-SanLV
Daniel
Las Vegas, NV
2025 Toyota 4Runner Off-Road Premium
I just found you online the other day and I see you've been doing this awhile. I am considering purchasing a camper trailer in the near future, and along with that I will need a brake controller, beefed up hitch and anti-sway bars, and will definitely be buying your transmission cooler. I'm tallying up a few add-ons that also will require removing the front fascias so I can hopefully only have to do that once.
Question: What about an oil cooler? Why don't you have one of those available?
Devon
Kansas
2026 TRD ORP
I could definitely see myself adding an engine oil cooling product in the future. I haven't really watched those temps as I've been focused on the transmission cooling for now.
