Extended Serrated Wheel STUDS
eassael
Eduardo
Mexico
Hi,
I bought new wheels for my 6G 4Runner Limited
ICON RECON SLX +40mm Offset but the OEM studs are too short and I cannot install the new wheels
Does anybody know part number, supplier, or any information where I can buy Extended Serrated Wheel STUDS?
2025 2026 4runner 6th gen Extended Serrated Wheel STUDS Short Studs
2025 2026 4runner 6th gen Extended Serrated Wheel STUDS Serrated stud exampl
Desert_6Gen
Eric
Bronco
the threads look long enough. Are you using aftermarket lugs because the stock OEM lugs will not work with aftermarket wheels.
eassael
Eduardo
Mexico
Hello
At the shop they told me that the thead its not long enough to tight the nut lugs. They told me that I need either a wheel spacer or longer wheel bolts so they can secure the aftermarket wheels.
So I am looking for a solution to install the new Icon wheels.
HuskyDan
Dan
Santa Clarita area, CA
'25 TRD ORPH, '13 Wrangler Sahara JKU
It is hard to tell if you've got room, but I just put RRW wheels on my TRD-ORP-H & used what is called "Extra Thread" lugs that I purchased from RRW. They have an extended portion of threads that go further down on the studs to provide more thread engagement and holding power. For these to work, they need to fit below the seat of the wheels. Your picture looks like that may not be possible as the clearance appears very tight.
Amazon link for a similar set: https://a.co/d/0bEEe085
2025 2026 4runner 6th gen Extended Serrated Wheel STUDS 1775688236201-os
