Burger Motorsports / OCC / Closed Ended
Will you consider the Burger Motorsports Oil Catch Can ?
  • Yes
  • No
  • Other Brand
Results are only viewable after voting.
Van Solo
Van
Calgary / Canada
Burger Motorsports / JB4 Oil Catch Can Install & Review.
We will update in 30 day and every oil change moving forward !
2025 2026 4runner 6th gen Burger Motorsports / OCC / Closed Ended 2024-2025-2026-toyota-tacoma-oil-catch-can.jpg
Update: Burger Motorsports Oil Catch Can to arrived !
Above:
Open the Box of Mystery!
2025 2026 4runner 6th gen Burger Motorsports / OCC / Closed Ended 1776306161219-yh
Above:
Make sure all your parts are present !
Below:
Locate your work area!
Above : Remove the 2 10mm Bolts!
Above:
Connect the bottom Adapter with the 2 Longest Allen Bolts to the Riser, now use the original 2 10mm bolts to reattach to OEM
Above:
Next attach the Oil Catch Can Mount to the Riser!
Above:
Mount the Oil Catch Can to the Riser!
Above:
Relocate the Original Hose to the left Oil Catch Can inlet, use the Burger Motorsports hose to the Original inlet on the Engine and the other side to the Oil Catch Can!
Below:
Now gently Pull back slightly on this hose to the forward of the engine bay to avoid any rubbing!
All done!
Just check the catch can every once in a while and empty and clean every Oil Change!
This install was very simple and took basic knowledge to perform.
We choose Burger Motorsports Catch Can because it had the the shortest hoses and this is critical for it to work well.
Hope this helps you all make the right choices for your 4Runner!
Update: Nothing noticable pertaining to driving or noises, I guess its one of those things that you wont notice until you decide to empty it out during the oil change.
agc
Austin
Cali
2026 4Runner
Great idea would love to see the follow up, following for updates
Removed Oil Catch Can
Project Terminated and converted back to stock.
Hmmm… inquiring minds would like to know why the relatively sudden change (1 month).
Van Solo
Van Solo
Van
Calgary / Canada
This was a personal choice to remain with Toyota design.
We change oil every 6500 with Valvoline Restore and Protect 5w30 full synthetic.
We run Redline SI-1 Fuel system cleaner every 3000km.
While Toyota master tech said the oil catch can may collect about 3% the added maintenance and our below -30 Degree during winter did not make me feel I need this mod to extend my engine life we opted to remain factory fit.
Last but not least we have a 180000km ECP plan with Toyota and will most likely trade in on the next gen 4Runner lucky number 7 if it’s not electric lol.
This post did not receive much traction either!
Thanks
