6th Gen 4Runner Air Connection Kit
AmericanAdventureLab
James
St. George, UT
2025 4Runner, 2011 4Runner
Welcome
American Adventure Lab
www.AmericanAdventureLab.com
Phone: 385.202.4188 | Email: [email protected] | Instagram: @AmericanAdventureLab
https://americanadventurelab.com/product/6th-gen-4runner-air-connection-kit/
One of the frustrations of onboard air systems is having to dig through gear, remove cargo, or access hard-to-reach compressor connections every time you need to air up tires or use air tools.
We wanted a cleaner, more accessible solution that integrates directly with the MASS Platform and allows quick access to your onboard air system without disrupting your cargo setup.
The American Adventure Lab 6th Gen 4Runner Air Connection Kit relocates your air connection to an accessible location that can be reached through the MASS access doors. Designed to work with ARB onboard air systems and the MASS Platform, this kit provides a clean, organized, and trail-ready air connection point that makes airing up faster and more convenient.
Features & Benefits:
• Designed for the 6th Gen Toyota 4Runner
• Designed specifically for use with the American Adventure Lab MASS Platform
• Relocates the air connection to an easily accessible location
• Allows tire inflation and air tool use through the MASS access doors
• Eliminates the need to unload gear or remove MASS Modules to access onboard air
• Designed for compatibility with ARB onboard air systems
• Compatible with optional ARB Pressure Control systems
• Precision-cut mounting plate
• Durable stainless steel hardware
• Designed to keep air system components organized and protected
• Built to withstand dust, vibration, and off-road use
• Provides a clean, professional-looking installation
• Made in the USA
• Designed and manufactured in St. George, Utah, USA
What's Included:
• Powder-coated mounting plate
• Air coupler and fittings
• Stainless steel hardware
• Detailed installation instructions
• Cutouts for ARB Pressure Control module and solenoid bracket
Installation Notes:
• Designed to integrate with American Adventure Lab MASS Accessory Trays
• Intended for onboard air systems such as the ARB Twin Compressor
• Designed around ARB compressor and pressure control configurations
• Installation instructions included
• Product photos may contain optional components not included with the kit
Frequently Asked Questions
What vehicles does this fit?
This Air Connection Kit is designed for the 6th Gen Toyota 4Runner.
Do I need to remove gear to access my air connection?
No. The system is designed so you can access the air connection through the MASS access doors without unloading gear or removing MASS Modules.
Will this work with an ARB compressor?
Yes. The kit was specifically designed around ARB onboard air systems and is compatible with optional ARB Pressure Control components.
What is the advantage of relocating the air connection?
Relocating the connection point makes it easier to air up tires or run air tools while keeping the system organized, protected, and readily accessible.
What hardware is included?
The kit includes a powder-coated mounting plate, air coupler and fittings, stainless steel hardware, and installation instructions.
Where is the kit manufactured?
The 6th Gen 4Runner Air Connection Kit is designed and manufactured in St. George, Utah, USA.
If you're building a 6th Gen 4Runner with onboard air, this kit provides a clean and convenient way to access your system without unloading gear or disrupting your cargo setup. Designed specifically for the MASS Platform and ARB-based air systems, it helps keep your setup organized, accessible, and ready for the trail.
We're happy to answer any questions about compressor compatibility, MASS Platform integration, or installation.
2025 2026 4runner 6th gen 6th Gen 4Runner Air Connection Kit IMG_4014 (2)
