Auxbeam (or other panels) mount on OEM trim
toothpaste22
Ryan
Dallas
Ive been toying with the different mounts (CaliRaised, 4Runner Lifestyle, etsy…,ect) and come to conclusion to just mount directly on to the OEM panel above the other switches/button.
Process is pretty simple, measure many times and drill once. Keep in mind, the OEM trim panel is NOT squared itself, so select your position/drill holes carefully.
DO NOT DRILL INTO MOUNTING CLIPS (I almost did, but it was mostly calculated lol)
Auxbeam provides a metal mounting bar that conveniently has 2 holes that matches up the mounting holes behind the switch panel.
Next, test fit and cut out a 3/16in notch on the top of the trim for the wire to fold/pass over, 1/2in hole in the inside trim (?) for the connector to pass through.
And voila! Pretty simple mount but very firm, wires tucked away, and without extra plastic that doesnt match OEM style.
ORRR just use 3M double sided tape, lol
Anyways, removing the trim is fairly easy. Easier if you remove the side trim(where the little compartment is) then pull out the mounting trim.
2025 4runner 6th gen Auxbeam (or other panels) mount on OEM trim IMG_5214
2025 4runner 6th gen Auxbeam (or other panels) mount on OEM trim IMG_5210
2025 4runner 6th gen Auxbeam (or other panels) mount on OEM trim IMG_5207
2025 4runner 6th gen Auxbeam (or other panels) mount on OEM trim IMG_5204
2025 4runner 6th gen Auxbeam (or other panels) mount on OEM trim IMG_5209
2025 4runner 6th gen Auxbeam (or other panels) mount on OEM trim IMG_5213
T_Pomp
Anthony
Illinois
2025 TRD Off Road Premium
I had to do the same thing I talked to the owner and thought they would have fixed this.
toothpaste22
toothpaste22
Ryan
Dallas
Looks like the 3rd party mounts are 3rd printed, not a complete plastic mold.
3D prints can definitely have good results, just matter of quality control
