Raptor Grille Lights - Which fuse location are you using?
kburrito
2025 TRD Off Road Hybrid
I'm wondering what people are using for the fuse taps for your raptor grille lights so that it doesnt turn on when doing evap testing.
Reading through FB groups and this forum, I dont really see a definitive answer.
Although I dont see my lights turn on (since i park on the street), I can see battery monitor on the dash reporting less when I start up the car compared to the previous night.
kburrito
kburrito
Battery voltage will drop due to weather & temp; but it shouldn't be below 12v; nothing to concern about. I have raptor lights & tapped into the IGN fuse. It never came on randomly in conjunction w/ EVAP system like other mentioned. I checked by putting a wifi camera in my garage that recorded a full 8 hours after park. Reviewed the footage shows no anomaly or random on.
My trim is 2026 TRD Sport Premium.
Ah thats good to know. Appreciate your response!
Are you able to take a picture of which spot in the fuse box you're using when you get a chance?
Hey OP, I found another fuse that you can tap into to fix the random turn on issue for the raptor lights. This was suggested from my certified mechanic friend. I tried & confirmed it's working!
You can use the same included 10A fuse.
“S/HTR R/L" 10A fuse refers to the seat heater circuit for the rear left seat. “S/HTR” is short for seat heater, and “R/L” means rear left. This feature is only on Platinum trim. It was blank in my car.
2025 2026 4runner 6th gen Raptor Grille Lights - Which fuse location are you using? 20260129_232958
2025 2026 4runner 6th gen Raptor Grille Lights - Which fuse location are you using? 20260129_214242(1)
2025 2026 4runner 6th gen Raptor Grille Lights - Which fuse location are you using? 20260129_232731
