What is the best/easiest way to get automatic front & rear cameras
Alaska Guy
Rich
Alaska
Do you mean Dash Cams? I'm also interested in this topic.
VB4Runner
Mitesh
2025 TRD ORP
There are a plethora of multi-channel dash cams that will offer front and rear cameras. I wanted a 4-channel cam with 4k in the front, but couldn’t find one that I liked so I ended up compromising on the video quality and got a LAMTTO 4-channel that records 1080p across the board. It has a front camera, two side cameras, and a rear camera.
Install was easy as pie. I sprung for a Dongar Pro which gives me parking mode and makes tapping into the existing power in the overhead console a breeze. I then used wall fish tape to pull the rear camera cable straight back to the cargo door. I mounted my rear cam to the cargo door window with adhesive tape.
All in, it was less than a 30 min install. Cameras are auto-on and the Dongar cuts power to protect the battery from drainage. There’s also an app to connect to the cameras to view footage.
Van Solo
Van
Calgary / Canada
WolfBox G900 TriPro @Wolfbox
Se my link below or builds page
Can also send % discount code if you want to buy? DM me
or Dual camera by FitcamX
use either link below in my signature area
JenningsESQ
Jon
2020 Tacoma TRD OR Premium
Van Solo
Van
Calgary / Canada
Wolfbox
Florent
Toyota 4runner
MartyMcFly
A lot of good information in this thread, thank you all.
