USB-C Cable by Pedals
Jimmy3711
Jimmy
MN
2025 TRD Sport Premium
Hey there,
I just noticed a USB-C cable that appeared from behind the hood release panel. Does anyone know what it goes to or what is for?
2025 2026 4runner 6th gen USB-C Cable by Pedals IMG_3286
2025 2026 4runner 6th gen USB-C Cable by Pedals IMG_3287
wth is this ??? that is not normal besides the cable. i suspect the cable to be a gps tracker type device
2025 2026 4runner 6th gen USB-C Cable by Pedals 1760741738914-1j
i retract my post on the screw attached item. its actually a part of the under dash. weird there is a customer facing screw, which is un-typical of toyota.
i went out and checked mine and its there also.
bkw777
Brian
NJ
25 SR5, 96 SR5
I just took a look behind that spot on mine and there is nothing like that. The screw is normal, not the usb cable. Absolutely I'd get back there and find what it goes to. It's all pretty open and easy to see in there without even taking anything apart. You might need back surgery but that's a seperate issue.
Gator
Calgary
2025 4Runner Platinum
Did you find out what it is for?
Jimmy3711
Jimmy
MN
I have not learned what it is for. I looked under the panel and it looks like the cable runs up by the Aux switch panel, but I couldn't see it past there.
