Van Solo
Van Solo
Van
Calgary / Canada
VanSolo thanks for the info and some photos with the 1.25” Peak Suspension Leveling kit. Here is my SR5 after the install. I’m running 275/75/18 Toyo Open Country AT3’s.
Looking good! are you pleased with the turnout?
I enjoy helping others and hope you are pleased with your choices?!
k9Hiken
jesse
New Kent Va
2025 SR5
I am. I currently waiting for the paint to dry on the rear recovery hook. I have just came back inside from installing the skid plate so the front end is complete for now since I’ve already installed the OEM front recovery hooks.
2025 2026 4runner 6th gen Stormtrooper by Van-Solo 4R (TRD Off Road Hybrid) IMG_9083
2025 2026 4runner 6th gen Stormtrooper by Van-Solo 4R (TRD Off Road Hybrid) IMG_9107
Van Solo
Van Solo
Van
Calgary / Canada
Very cool, you opted for the TRD aluminum skid plate I see, did you also do the transmission and rear differential plates?
k9Hiken
jesse
New Kent Va
2025 SR5
I will be doing the rear differential for sure.
Van Solo
Van Solo
Van
Calgary / Canada
toyoda80
Beau
ME-SO Switch-Back Interior light upgrades / White-Red
Tacoma 4G map lights & Dome lights fit 100% in 4Runner
Install video here:
was the double sided tape necessary to reinstall the bezel or would it have snapped back on? Thanks
Van Solo
Van Solo
Van
Calgary / Canada
It was added to reduce the plastic vibes, it does snap back in normally.
Van Solo
Van Solo
Van
Calgary / Canada
TSB Brake Squeal - Completed Today, will let you know if it works.
Well, that did not work it remains with a squeal, however the dealer has a solution.
Next week back in for a redo and upgrade not included in the TSB.
Stay tuned.
Van Solo
Van Solo
Van
Calgary / Canada
Trailhunter / TRD Pro mudflap upgrade today (Save The Paint)
Also wanna maintain some OEM parts where I can !? and these worked out well.
Part numbers for the Trailhunter / TRD Pro mudflaps:
PK389-35S10-F1
The install is 2 Phillips Crews & 1 Push plug and a Screw in the rear
PK389-35S10-R1
The install is 2 Phillips Screws & 2 10mm Bolts on the rear
Tires size and wheel 285/70R17 with 17x8 +25
Here are some images of the coverage:
2025 2026 4runner 6th gen Stormtrooper by Van-Solo 4R (TRD Off Road Hybrid) Trailhunter TRD Pro mudflaps installed on 2025 4runner 6th gen5
2025 2026 4runner 6th gen Stormtrooper by Van-Solo 4R (TRD Off Road Hybrid) Trailhunter TRD Pro mudflaps installed on 2025 4runner 6th gen1
2025 2026 4runner 6th gen Stormtrooper by Van-Solo 4R (TRD Off Road Hybrid) Trailhunter TRD Pro mudflaps installed on 2025 4runner 6th gen4
2025 2026 4runner 6th gen Stormtrooper by Van-Solo 4R (TRD Off Road Hybrid) Trailhunter TRD Pro mudflaps installed on 2025 4runner 6th gen3
2025 2026 4runner 6th gen Stormtrooper by Van-Solo 4R (TRD Off Road Hybrid) Trailhunter TRD Pro mudflaps installed on 2025 4runner 6th gen2
Van Solo
Van Solo
Van
Calgary / Canada
I found these on a few websites, Aliexpress being the cheapest. Did you get yours yet and where did you order them?
Picking up my new Heritage Blue 4Runner Monday, so ordering up accessories shortly.
2025 2026 4runner 6th gen Stormtrooper by Van-Solo 4R (TRD Off Road Hybrid) tempImage4AO6Yq
s3lekta
M
ON, Canada
Can you share the Trailhunter / TRD Pro mudflaps part number #’s ? Thanks!
