5 Sets of 2 Beeps
tpmacleod
Tim
Vancouver, BC
2026 TRD Pro / 2014 Limited
Okay. Here is a new one.
Only on the passenger door and mostly when opening the door, the 4Runner does 5 sets of two beeps. I also hear clicking in the rear door.
it just started and can it figure out what is going on. A few times it occurs when closing the door.
Any thought?
did at anytime you open the rear doors ???
its a safety feature to remind you either you put something in the rear seats (kid, dog, person)
if you open the rear doors and close it, toyota assumes someone got into the back seat and to remind you someone is back there. its a crude system vs the front seat weight sensors
likely this...it can be disabled so rear door access reminder doesn't bark at you
tpmacleod
tpmacleod
Tim
Vancouver, BC
Hi
I will play with that setting. It just started happening so it is a bit odd since nothing was changed. But if turning it on and off could trigger a fix that would be good.
It happens mostly on the front passenger door. About 90 percent of the time. It happens even if the rear doors are not opened first. It has occurred when trying to open the hatch and also locking the vehicle and opening.
At least there is a starting point.
Thanks.
