Wind Noise Mod?
TBONE21
High Point, NC
2025 TRD OFFROAD
Hey everyone. Does everybody hear that wind noise on your left ear? It sounds like a seal is leaking air over 60mph. Everything looks normal when checking all the seals. If there is an issue, then is there a mod out there to quiet it up?
Thanks in advance
RunnerRocks
RedDog
Nature
2026 TRD ORP (non-hybrid)
Thanks in advance
I hear wind noise and a slight buffeting sound even when there is no wind. I pushed out on the drivers door and window which made no difference.
Removed my roof cross bars which made no difference. They were coming off anyway.
I'm wondering if the sound is from around the outside mirrors.
1Volfan
Chuck
Cincinnati
People on the LC and GX forums talk about adding rubber trim on the sides of the windshield to reduce noise. Haven’t really noticed an issue on my Trailhunter, though, since the snorkel tends to drown it all out 😂
mattfuria
Cincinnati, OH
2025 Black 4Runner Limited - 1999 Jeep Wrangler TJ
I've noticed the wind noise, even after disabling fake engine noise and white noise with Carista. Removing the roof cross bars helped with noise over 50MPH, but now I think I notice the door noise more (almost as if a window is down). Similar noise to my 5G 4Runner.
I've read in 5G forums of people lining the inside of the door gasket profile with another material to cut down on that noise, like backer rod or hollow soft plastic tubing. Though I've not tried this fix.
Anicholson1234
Allan
Napa
4runner, Tacoma
I also noticed the wind noise on the drivers window in the corner at around 50MPH. If you put your finger in the corner of the window between the seal and push slightly against the glass the noise stops. I will try adding a small piece of additional rubber in the seal in the coming weeks and se if that helps.
TBONE21
High Point, NC
2025 TRD OFFROAD
The corner at the top by the B pillar?
Doofy
Hamilton, ON Canada
2025 4R
I noticed a specific noise at the sunroof. If i tilt it open and let it auto-close , the noise starts
(Yes, it starts after the roof is closed…)
I have to slide it open and let it auto-slide-close to eliminate the noise.
The noise only comes back on the tilt open and tilt close
It has to do with how the window sets back down on the seal I think? Anyone else notice the same?
4hunter
Dane
Phoenix Arizona
I'm glad I'm not the only one.
Thanks in advance
Glad I'm not the only one. I have a 25 TH and feel like I'm in a wind tunnel anything over 50mph. Over 70 and you cant hear anything. I literally have to yell to talk with my wife. When I talked with the dealership about it. I was told they could replace the door seals but it likely would not fix the problem. I cant for the life of me believe why a 70k vehicle is this poorly designed. I do have a Wescott Rack but I have narrowed down the noise to the top rear corners of the driver and passenger doors. Also the rear quarter windows. Which are super loose and can freely be moved within the seal (still haven't figured out the reason for this). I have a 14 Tundra SR5 that is much quieter. I'm hoping there is a fix for it at some point. Weather it be the dealer or an aftermarket option.
add these to the rear door b-pillar edge it makes a big difference for real
https://www.amazon.com/dp/B0G33X396H?th=1
the b-pillar transmits noise directly to your ears
this deadens noise from front and back door panels
and cuts any wind noise in the crack between them.
I now only hear noise from elsewhere around the vehicle but
right where my ears are, a lot more quiet.
at all speeds an improvement
on highway I can now hear every subtle
spin up of the turbo whereas above 45mph
wind noise mostly took over turbo noise
blocks noise from other vehicles around you
these dang $9.99 seals are doing a $250.00 dollar job
again, since it is the b-pillar that is closest to your ears
that gets quieted down, it has huge effect on cabin noise
4hunter
Dane
Phoenix Arizona
Can you post pictures of where you put the seals? Know where the back of the B pillar post is. But I'm not sure where you installed the seals at. Did you remove the factory seals to put these on?
these seal the gap between front door and rear door
