When You Want More Reach: 40" PRO for the 2025+ 4Runner
MandRonline
Colby
Burbank CA
Toyota 4Runner TRD Pro
2025 2026 4runner 6th gen When You Want More Reach: 40" PRO for the 2025+ 4Runner Rugged 4Runner Light Bar Showcas
If the smaller light bar setups aren’t quite enough and you want a bigger jump in forward lighting, our 2025+ Toyota 4Runner 40" PRO Light Bar Kit is built for exactly that. The curved PRO bar mounts in front of the grille and gives you a lot more usable light without needing to put anything on the roof.
The PRO series uses a spot + driving beam pattern, so you get a combination of longer-distance lighting and wider coverage. It’s a good setup for trails, back roads, camping, and nighttime off-road driving where you want to see farther ahead and more of what’s around you.
A few things that stand out:
  • Vehicle-specific fitment for the 2025+ 4Runner
  • Curved 40" PRO light bar
  • Strong forward output with a spot + driving beam
  • Mounts in front of the grille
  • No cutting or drilling required
  • Designed so it doesn’t interfere with radiator airflow
  • Available with white or yellow main output plus amber DRL backglow
Here’s a look at the light output:
If anyone has questions about fitment, installation, or the setup itself, feel free to ask.
MandRonline
MandRonline
Colby
Burbank CA
For anyone following the 2025+ Toyota 4Runner 40" PRO light bar setup, here’s an install video showing how the kit goes together.
It gives you a closer look at the mounting process, light bar placement, wiring, and what’s involved with the installation from start to finish.
MandRonline
MandRonline
Colby
Burbank CA
Here's the 40" PRO with the white main beam on a 2025+ 4Runner. The kit is in stock and ships free anywhere in the continental U.S., and it comes with a lifetime warranty like all of our light kits. If you want a shop to install it, here's our trusted installer list: https://mandronline.com/pages/trusted-installers
2025 2026 4runner 6th gen When You Want More Reach: 40" PRO for the 2025+ 4Runner 2025-Toyota-4Runner-40in-Light-Bar-PRO-Whit
MandRonline
MandRonline
Colby
Burbank CA
One more look at the 40" PRO on a 2025+ 4Runner, plus a video of what the 40" PRO puts out at night.
2025 2026 4runner 6th gen When You Want More Reach: 40" PRO for the 2025+ 4Runner 4runner-40-pro
  • Fits 2025-2026 4Runner in TRD Sport, TRD Sport Premium, TRD Off-Road and TRD Off-Road Premium, including the i-FORCE MAX versions
  • Mounts in front of the grille, and the bar only covers a small part of the opening, so airflow stays open
  • Complete bolt-on kit that uses the factory openings and hardware, with no cutting or drilling
Not sure which trim you have? Email us a picture and we'll confirm fitment.
Forum members get 10% off with code 4runner6g at checkout.
2025+ Toyota 4Runner 40in Light Bar PRO
