When You Want More Reach: 40" PRO for the 2025+ 4Runner
MandRonline
Colby
Burbank CA
Toyota 4Runner TRD Pro
2025 2026 4runner 6th gen When You Want More Reach: 40" PRO for the 2025+ 4Runner Rugged 4Runner Light Bar Showcas
If the smaller light bar setups aren’t quite enough and you want a bigger jump in forward lighting, our 2025+ Toyota 4Runner 40" PRO Light Bar Kit is built for exactly that. The curved PRO bar mounts in front of the grille and gives you a lot more usable light without needing to put anything on the roof.
The PRO series uses a spot + driving beam pattern, so you get a combination of longer-distance lighting and wider coverage. It’s a good setup for trails, back roads, camping, and nighttime off-road driving where you want to see farther ahead and more of what’s around you.
A few things that stand out:
  • Vehicle-specific fitment for the 2025+ 4Runner
  • Curved 40" PRO light bar
  • Strong forward output with a spot + driving beam
  • Mounts in front of the grille
  • No cutting or drilling required
  • Designed so it doesn’t interfere with radiator airflow
  • Available with white or yellow main output plus amber DRL backglow
Here’s a look at the light output:
If anyone has questions about fitment, installation, or the setup itself, feel free to ask.
MandRonline
MandRonline
Colby
Burbank CA
For anyone following the 2025+ Toyota 4Runner 40" PRO light bar setup, here’s an install video showing how the kit goes together.
It gives you a closer look at the mounting process, light bar placement, wiring, and what’s involved with the installation from start to finish.
