Transfer case skid plate that's compatible with TRD skid plate? (part number)
jbol74
Jerrod
2025 4runner trd off road
What is the part number for the compatible transfer case skid plate to go with the trd skid plate? Non hybrid ORP Thanks
RunnerRocks
RedDog
Nature
2026 TRD ORP (non-hybrid)
I have this one for my 2026 ORP (non-hybrid)
Transfer Case Skid Plate
Part Number: PT228-35248
4running
TX
2020 4Runner SR5
AdFour
Washington
RunnerRocks
RedDog
Nature
So you don’t have both?
Have both. Did lots of research before purchase. Front TRD skid is installed. Transfer case skid goes on soon when lift is installed. So I can't tell you from experience (yet) that it fits.
jbol74
Jerrod
Front Trd Aluminum skid: PTR60-35240 (Trailhunter skid will work for non hybrid)
Transfercase STEEL skid: PT228-35248 (PT228-35247 for hybrid)
Rear Diff STEEL skid: PT228-89254 (Will work for both hybrid and non)
In your case PT228-35248 for transfer and PT228-89254 for rear diff if you want
for details / mistakes:
https://www.4runner6g.com/forum/thr...cation-front-transfer-case-skid-install.4669/
Cool! So ptr60-35240 and pt228-35248 are compatible ? Correct? I ask because I seen someone selling on on eBay and they said it’s not compatible with the ptr60-35240… for the record no I’m not buying on eBay. Toyota dealer only … thanks
AdFour
Washington
Ive installed PT228-35248 with PTR60-35240 (non hybrid like yours) works fine
jbol74
Jerrod
Also just curious if youve noticed any handling, performance, or gas mileage changes since installing? Thanks
AdFour
Washington
None that I can feel or measure for, the total weight is only about 50 lbs. They are streamlined to frame similar to the original plastic front, just heavier. You can't convince me you'd feel anything with a 1.1% increase in weight for all 3.
jbol74
Jerrod
Wouldn’t the total weight be around 100lbs for all 3. Front roughly 30lbs, trans roughly 50lbs, and rear roughly 20lbs? Does that sound about right? And nice to hear you haven’t noticed any difference. Thank you for your help. It’s greatly appreciated
