What boxes are you guys using on your roof racks?
mcd_ovrlnd
SE PA
2025 4Runner TRD PRO
Damn. I havent even been on FB in years and never even used Marketplace, but damn if I wont start now šŸ˜…
I just saw a Roam 86L by me for $250. That’s $100 off. You could probably get it for $200. It’s worth running searches on it for Roam a few times a week.
ThatSickRIp
TSR
2026 4Runner SR5
Thule XL. Ordered from Subaru for my Outback Wilderness. I’d like some proper boxes, but this fits a lot and is very convenient to put on/take off.
Think it migh be larger than what I want since it takes up so much space, but will look at it to have all my options sorted.
More importantly, where is that? Thats an amazing view. Damn. :love:
ThatSickRIp
TSR
2026 4Runner SR5
I went with 2 rifle cases from Harbor Freight.
I need to get to a HF and look at these.
Did you take the foam out or cut it to fit what you are putting in there? The listed height is one of my concerns and Im worried about it limiting what it can store.
How did you secure it to the rack? Drill holes and put some T nuts/bolt through it to anchor them?
PearlyGates
Shane
AL
Yeah, removed all the foam, and used 4 hex head bolts and nyloc nuts to secure to the rack. The dometic Frontrunner rack holds the hex head bolts from the underside. I use one case for recovery gear and the second case for camping gear as needed. I also have a platform from Greenlane Offroad which provides more storage.
2025 2026 4runner 6th gen What boxes are you guys using on your roof racks? IMG_4052
2025 2026 4runner 6th gen What boxes are you guys using on your roof racks? IMG_4053
2025 2026 4runner 6th gen What boxes are you guys using on your roof racks? IMG_4054
ThatSickRIp
TSR
2026 4Runner SR5
Nice! You happen to know the internal height with the foam removed? Id love to keep my M18 inflator up there if its tall enough.
ThatSickRIp
TSR
2026 4Runner SR5
I measured ~5 1/2 inches for the base and lid.
Thanks! That wont let the M18 inflator fit, but damn if I couldnt get most of the rest of the stuff I wanted in there to fit.
37thChamber
Todd
St. Louis
Tetons this past July.
ThatSickRIp
TSR
2026 4Runner SR5
FYI Roam having early Black Friday. 30% off.
Thanks for the heads up! Just added a 95L, lid organizer and just did the normal tie downs and was at $600. Think the Roams might be a little too rich for my blood considering the handful of times a year Id be using them. I have to take them off when not on a road trip because I wont be able to fit in the garage with them on
I did find these at Lowes, sizes are good but I just need to go check the out to see how thick the walls are and make sure theyre not flimsy
Theyre smaller, so Id probably do 2 side by side. They say 21" x 14" x7", so the M18 inflator should fit
2025 2026 4runner 6th gen What boxes are you guys using on your roof racks? 84148595
This one looks interesting if the drawer will clear the racks side rails. About 2.5" taller than the Roam, so not huge height increase
2025 2026 4runner 6th gen What boxes are you guys using on your roof racks? 84148916
