Protection from Rodents?
william johnson
los angeles
2026 4runner iforce max
My 2008 4Runner was totaled when parked outside in Los Angeles the wiring was consumed by rodents. Has Toyota made any improvements in protecting the wiring, I have a 2026 4Runner which I suspect had even more accessible sensitive wiring.
josiahg52
Josiah
Maine, United States
Not really. Pretty much the same. Over what time frame did this occur?
william johnson
los angeles
I was the victim of two attacks. One was over about 10 days and the insurance company paid to replace 12 wiring harnesses. The second was over more than a month and the insurance company paid me $18,000 and totaled the car. I preferred my 2008 over my 2026 4Runner. The hybrid battery and turbocharger add issues with very little benefit.
plukaz
Paul
Chicago
2026 4Runner SR5, 2023 4Runner Limited
I can't comment on if it's better than your previous 2008 and you may already know this, but as general FYI.. The rodents are attracted to the vegetable and Soy coated wiring. Most of what i see in my 2026 engine bay is protected by corrugated plastic wire loom - which is polyethylene - so it should be ok. If you see exposed wires, tape them with petroleum-based vinyl high-heat electrical tape. The other option is to use a chayene pepper / pepermint oil spray - which is temporary. It also has an obvious smell to us humans, but I've had success with an older vehicle I store outside spraying it around the wheel well liners, bottom of the chasis and on engine bay insulation - just keep it far away from the cabin air intake vents. I reapply every few months and I've not had a problem after an initial issue where some sound baffling was eaten - I soaked that part until it was dripping :)
ok seriously
all bets are off but when I saw a few videos online of a camera watching
mice and rodents going for seeds left out, and then the guy tried mint and other
things, the minty stuff the rodents straight out avoided
this is likely the best thing to do and it does and doesn't work sometimes
but it is better than doing nothing
get these on amazon
Motrapso
Peppermint Oil to Repel Mice and Rats, 4 Pack Rodent Repellent
They are circular tin cans of mint and smells rodents absolutely do not prefer
and they have an adhesive pad on the back. like an air freshener gel inside that
eventually evaporates away
Under the hood I have two stuck near the windshield passenger corner on some flat
plastic, and 2 stuck near the (non hybrid) 12v battery on front driver side
When I walk by the 4runner while parked I can smell this mint wafting
I change these every 3 months or so when they are depleted
it has kept the chipmunks out of my 4runner for sure.
rodents are gonna rodent, but this seems legit
the 4runner does have a fairly good design around the cabin air intake, it is not easy for
a critter to crawl straight into the air intake like on rav4's. but if you want to be sure
you need to remove the plastic cowl and install a metal screen over the cabin air
intake to 100% keep critters from going in there and causing internal damage
Oh and for sure, my Yaris was about taken over by mice. I started using cotton balls and raw peppermint oil in strategic locations and they disappeared and never came back
... and a spray bottle with peppermint oil or rodent repellent, and a quick walk around every once in a while blasting bits of the underside and wheel wells will help too
dante116
Sacramento, CA
2026 4Runner Off-Road Premium
ok seriously
get these on amazon
Motrapso
I've used mint oil on my outdoor vehicles for years and have had zero evidence of rodents, where before using it I had found chewed wiring and droppings all over the engine area. I use the dropper the bottle comes with and place drops all around the engine bay in any little divot that can keep it there without running off. I re-apply it about every 2-3 weeks. Works like a charm and is way cheaper than new wiring. Plus it doesn't smell half bad, especially when the engine heats up.
