More secure key fob chain?
jimbo285
Jim
Fairbanks
Has anyone found a keyfob cover that doesn’t have the ring attach to the “emergency” key? I am nervous about the fob accidentally detaching from the keyring and not realizing it’s gone. I keep seeing ads for replacements but unsure if the ring attaches to the fob “body” or the slide-out key.
4RunnerTony
Tony
Venice Florida
Mine attaches to the slide out key but there is a latch that must be pushed to remove the key. The latch is very hard to push and get the key out so it should not be a problem.
in the last 15 yrs or so of using toyota fobs with keyring in emergency key (2014 4R, 2016 taco, 2018 tundra, 2023 tundra, 2025 4R), i have yet to have one accidently pop out of the case either use the oem case or ajt designs keyfob case. the ajt design fob case transfers the latch mechanism from the oem case to the new case.
and you have really force the latch on the ajt fob case to get the emergency key out (if you have one of the early designed ones, later ones he changed the design were its easier to slide the latch over).
the latch button is recessed quite a bit so you have to really jam something in there to release it if you have it in your pocket.
the red screw one is the 2023 tundra, the blue screw one is the 2025 4runner
also he has a blank insert for the rear hatch button so you cant accidently open the rear gate.
2025 4runner 6th gen More secure key fob chain? 20260217_055003
