MagnaFlow
Oceanside, California
Check out this MagnaFlow Overland Series exhaust system install, improving both sound and clearance.
The MagnaFlow Toyota 4Runner Overland Series Cat-Back Performance Exhaust System #19657 is engineered for off-road function and built to explore further. This Toyota 4Runner exhaust system is designed for the 2025-2026 Toyota 4Runner equipped with the L4 2.4L GAS engine. The high clearance exhaust design of this kit is intended to keep your truck clear of any challenging terrain or obstacles you may come across.
MagnaFlow Overland Series Exhaust System
YouTube Install
Beedeviled
Stacey
2026 4Runner Limited
Interested in hearing feedback on this system. There’s a bit of a trend here with folks reporting a persistent drone in that ~1500-2000k RPM range on the 4R with aftermarket systems. Although, when people mention it, they don’t necessarily describe how loud it is, are they on level ground or incline, whether they’ve had aftermarket systems in the past, or what mode they’re driving in. Every aftermarket system will be noticeable compared to stock, although, drone is definitely a thing. For example, wouldn't be surprised to hear that a drone is more prevalent in eco mode due to a higher potential for transmission lugging.
Joestac
Buys an overland exhaust to prevent the factory one from hanging down too low while also having a ridiculous recovery arm sticking out even lower.
