4running
TX
2020 4Runner SR5
How To Remove The Front Bumper On A 2025+ 4Runner 6th Gen (DIY instructions)
Summary:
  • Removing Grommets & Screws: Once the hood is open, there are several grommets and screws visible on the front panel area that must be removed to access the bumper assembly components. These are mostly plastic fasteners that come out easily with a trim tool or screwdriver.
  • Detaching Engine Bay Cowling: Two key plastic cowlings, one over the intake and another near the radiator, must be removed next. They are held in place by press-down clips. The owner demonstrates how to depress these clips and lift the pieces out without damaging them or losing the associated grommets.
  • Unplugging Electrical Connectors: Before removing physical bumper hardware, it's necessary to disconnect two electrical wiring harnesses. One is black and the other white; using a screwdriver to press the locking tabs makes unplugging easier and avoids pin damage.
  • Removing Side Liner Bolts: A crucial step involves removing six bolts that secure the bumper to the side liner. These bolts are laid out vertically along the inside edge of the wheel well.
  • Undoing Clips & Releasing Bumper Corners: Several plastic clips must also be popped out before the bumper corners can be freed. The bumper sides are then gently pulled out, a motion that requires even pressure to avoid cracking the panel.
  • Repeating Process on Passenger Side: All steps from the driver’s side are mirrored on the passenger side—undoing the bolts, removing the clips, and popping out the bumper edge. Final Bumper Detachment: The last part involves removing three large bolts that keep the bumper securely mounted to the vehicle's frame. With those removed, the bumper can be pulled off cleanly, revealing full front access for mods or maintenance.
