Anyone remove the charging warning sticker (from wireless charger pad)?
gardner2303
Grant
Lakeville, MN
2025 TRD Sport
Assume this would be fine to remove but wasn’t sure if there are any unforeseen issues removing or if it actually looks worse.
Updated with answer from @4RunnerWasStolen! below:
"I easily removed the sticker with no residue or issues."
2025 4runner 6th gen Anyone remove the charging warning sticker (from wireless charger pad)? IMG_4253
timelapse
ATL
2025 ORP
More likely to remove the charger.
Have you had a chance to figure out how it could be removed and/or replaced? The OEM wireless charge won’t reliably charge though my Apple silicone case (it is MagSafe compatible). Meanwhile, works fine on my wife’s Apple case that’s a different material. I’d love to pull it out and 3d print a setup with MagSafe so the phones don’t slide off the charger. Would be nice to tap into the power used by the OEM charger.
gardner2303
gardner2303
Grant
Lakeville, MN
2025 TRD Sport
Sorry, feel like I did a poor job of wording this post with the more specific part of the question in the title and not really explaining in the post. Luckily my phone seems to be charging fine so will leave the charger as is, what I am curious about is about removing the super bright warning sticker. Concern is I start to pick at it and immediately regret it making it look worse than if I just leave it alone. I assume this comes off and goo gone could take care of anything remaining... but hoping someone has already confirmed :)
2025 4runner 6th gen Anyone remove the charging warning sticker (from wireless charger pad)? 2025-03-23 09_07_15-(13) Anyone remove the charging warning sticker (from wireless charger pa
timelapse
ATL
2025 ORP
Your original question was clear— it just prompted me to ask other questions.
When I take delivery of my 6th gen, I plan to remove that warning decal. Have you tried to peel it off?
If you’re uncomfortable doing that, apply a piece of black electrical tape or matching 3m vinyl to cover the warnings.
timelapse
ATL
2025 ORP
ELS4x4
2019 Audi SQ5
Going to piggy back on this thread. How does the phone stay in place without flopping all around? Is there a clip or something on the bottom where the phone interfaces with the floor of the charger?
timelapse
ATL
2025 ORP
Based on the 4th gen Tacoma users, it doesn't. Unless you have a very big phone, most devices (e.g. iPhone 16 Pro) will slide around while driving and stop charging. I haven't read about many users who find it reliable as a result. I was going to just pull the fuse on the OEM charger and plug in a MagSafe charger above it.
lucy.vp_
Lucia
2025 4Runner TRD ORP
I have some random MagSafe iPhone case, and my charger works just fine, and my phone doesn't slide around
MartyMcFly
Anyone tried upgrading the charger pad somehow? It's such a slow charge I've been using the USB cable instead.
kobyneal
Kolby
Calgary Canada
2024 Prius & 2024 Land Cruiser
Anyone find a rubber cover or mat that stops your phone from slipping? Land Cruiser (albeit sits flat) has a number of options that prevent that and damage to the charger from your phone sliding around
Underground25
Central Colorado
I just have a slim silicone case and it charges great, no sliding around.
