- Joined
- May 1, 2025
- Threads
- 72
- Messages
- 206
- Reaction score
- 102
- Location
- Texas
- Website
- offroadusa.com
- Vehicle(s)
- 06 V8 for now
- Thread starter
- #1
Upgrade your 2025+ Toyota 4Runner with powerful Baja Designs grille and fog light kits for bold style, trail‑ready performance, and safer night driving
If you drive a 2025+ Toyota 4Runner and love pushing it off the beaten path, upgrading your lighting is one of the most dramatic performance and style mods you can make. In this guide, we'll walk you through three powerhouse Baja Designs upgrades designed specifically around the 4Runner: a Squadron Pro behind‑grille kit, an S8 10" + S2 Pro grille replacement kit, and the S2 Sport OEM fog light replacement kit for non‑TRD Pro models.
Why Upgrade Your 4Runner Lighting?
The stock lighting on the 2025+ 4Runner is fine for commuting, but falls short when you’re bombing down fire roads, crawling rocky passes at night, or dealing with nasty weather. Better lighting gives you more usable light down‑trail, wider peripheral coverage, and a massive boost in trail confidence.
Upgrading to high‑output LED systems like Baja Designs brings several advantages:
Product 1: Baja Designs Squadron Pro Behind‑Grille Kit (2025+ 4Runner)
The Squadron Pro behind‑grille kit for the 2025+ 4Runner is all about stealth power – you get serious forward lighting while keeping your factory front‑end look. This kit mounts high‑output Squadron Pro pods behind the grille using model‑specific brackets and wiring.
Key Benefits
Ideal Use Cases
Product 2: Baja Designs S8 10" + S2 Pro Grille Light Replacement Kit (4Runner)
The Baja Designs S8 10‑inch and S2 Pro grille light replacement kit transforms the front of your 4Runner into a functional light wall, replacing sections of the grille with a tightly integrated light bar and auxiliary pods.
What This Kit Includes
While specific contents vary slightly by configuration, this type of kit typically includes:
Benefits for 4Runner Owners
Product 3: S2 Sport OEM Fog Light Replacement Kit (2025+ 4Runner, Non‑TRD Pro)
The Baja Designs S2 Sport OEM fog light replacement kit is aimed at 2025‑on 4Runner owners with non‑TRD Pro trims who want better fog and cornering light performance without custom fabrication.
Direct OEM Fog Replacement
These kits are built to drop into the factory fog light locations, using brackets and housings shaped to the 4Runner’s bumper openings.
Perfect For Non‑TRD Pro Trims
If you’re running SR5, Limited, or other non‑TRD Pro trims, this kit is a direct way to match or exceed the lighting performance often associated with premium packages. It is one of the most cost‑effective lighting upgrades you can make on a 4Runner because you’re replacing a weak factory component with a high‑end off‑road fixture right where you need it.
How These Three Upgrades Work Together
You don’t have to choose just one of these kits. The magic happens when you combine them and build a layered lighting system around your 4Runner.
Choosing the Right Lighting Package for Your Driving Style
To pick the best combination for your 4Runner, start with your primary use case.
Mostly Daily Driving with Occasional Trails
Weekend Warrior and Exploration
Heavy Off‑Road, Overlanding, or Night Runs
Installation Considerations for 4Runner Lighting
Before you click “buy,” factor in installation complexity and supporting components.
Fitment and Compatibility
Wiring and Switching
High‑output LEDs draw more current than stock, so harness quality matters.
DIY vs Professional Install
Many 4Runner owners with basic tools and patience can install these kits at home.
Feature Highlights to Look For
When comparing these and similar 4Runner lighting kits, keep an eye on specific performance specs and design features.
Output and Beam Pattern
Durability and Weather Resistance
Vehicle‑Specific Design
Generic bars can work, but 4Runner‑specific kits save time and look better.
FAQs about 2025+ 4Runner Lighting Upgrades from Baja Designs
Do I need to upgrade my 4Runner’s wiring to run these Baja Designs kits?
Most vehicle‑specific kits include harnesses engineered to handle the current draw of the lights without overloading factory circuits. You typically run power directly from the battery through a fused relay, then trigger that relay with an interior switch. Always follow the supplied instructions and never just tap high‑output lights into thin factory headlight wiring.
Are these lighting upgrades legal for on‑road use?
On‑road legality depends on your local regulations and how you aim and use the lights. Fog light replacements that follow OEM placement and proper aiming are often more road‑friendly, while high‑output bars and behind‑grille kits may need to be used only off‑road or when no traffic is present. Check your state or country’s lighting laws, especially regarding auxiliary high‑beam lighting.
Will these kits work with my 2025 4Runner if it’s not a TRD Pro?
Yes, the S2 Sport OEM fog light replacement kit mentioned here is specifically designed for 2025‑on non‑TRD Pro 4Runner trims. The behind‑grille Squadron Pro kit and S8 10" + S2 Pro grille kit are also targeted at the 4Runner platform, but always double‑check the fitment notes for your exact year and trim before buying.
Can I run all three kits at the same time without draining my battery?
When wired correctly with relays and appropriate fusing, you can run multiple LED kits safely because modern LEDs draw far less power than old halogen or HID systems for the same light output. For extended idling with lights on, a healthy battery and alternator are important, and frequent night‑time overlanders sometimes upgrade to higher‑capacity batteries or dual‑battery setups for extra headroom.
What’s the best first lighting upgrade for a 4Runner on a budget?
If you’re cost‑conscious but want a noticeable improvement, start with the S2 Sport OEM fog light replacement kit for non‑TRD Pro 4Runners. You’ll see a major increase in near‑field and bad‑weather visibility, and you can always add the behind‑grille Squadron Pro kit or the S8 10" + S2 Pro grille kit later as your needs and budget grow.
- Huge increase in lumens and usable beam distance compared with stock.
- Better color temperature for reduced eye fatigue and improved contrast on dirt, rocks, and obstacles.
- Rugged, off‑road‑ready housings with impact‑resistant lenses and weather‑sealed construction.
- Vehicle‑specific brackets and harnesses for a clean, factory‑worthy install on the 4Runner.
Key Benefits
- Stealth mounting: Lights are hidden behind the grille, keeping a clean OEM appearance while delivering big performance.
- Massive output: Squadron Pro pods are among Baja Designs’ highest‑output compact lights, ideal for high‑speed off‑road driving.
- Integrated fit: The brackets and hardware are tailored to the 2025+ 4Runner grille shape for a tight, rattle‑free install.
- Switch integration: Kits commonly include harnesses that tie into factory‑style switches or aftermarket switch panels.
Ideal Use Cases
- Fast desert or forest trail runs where you need long‑range spot or driving beams.
- Rural highway use where wildlife and unlit roads demand more visibility.
- Drivers who want “sleeper” looks – no obvious aftermarket bar hanging from the front.
- A 10‑inch S8 LED light bar that fits into the grille opening.
- A pair of S2 Pro pods for additional spot or wide‑cornering coverage.
- Vehicle‑specific mounting brackets engineered for the 4Runner grille.
- Plug‑and‑play or near plug‑and‑play wiring harness options.
- Bold, aggressive look: Unlike the stealthy behind‑grille setup, this kit puts your lighting upgrade front‑and‑center in the grille.
- Balanced beam pattern: Combining the S8 with S2 Pro pods gives both forward reach and side illumination for technical trails.
- Great for dual‑purpose rigs: Powerful enough for serious off‑road use, but also excellent for rural night driving and overlanding.
- Clean integration: You avoid awkward universal brackets; instead, the kit follows the 4Runner’s factory lines.
- OEM‑style fit: No hacking up plastic; the brackets use factory mounting points.
- Clean wiring: Harnesses are designed to interface with the stock fog light connectors or simple adapters.
- S2 Sport output: The S2 Sport is a compact but potent cube that significantly outperforms stock fogs in brightness and beam quality.
- Behind‑grille Squadron Pro kit: Primary high‑speed forward lighting with serious throw.
- S8 10" + S2 Pro grille kit: Fills in mid‑range and wide field of view while giving an aggressive visual upgrade.
- S2 Sport fog replacement kit: Low‑mounted lighting for fog, dust, snow, and slow‑speed technical work.
- Start with the S2 Sport fog light replacement kit to boost low‑beam performance, visibility in bad weather, and close‑range trail lighting.
- Add the S8 10" + S2 Pro kit if you want a more aggressive look and better visibility on dark backroads.
- Make the behind‑grille Squadron Pro kit your first major upgrade for serious forward light at speed.
- Pair it with the S2 Sport fog replacements so you have both distance and low‑mounted fill.
- Run all three: behind‑grille Squadron Pros, the S8 10" + S2 Pro grille kit, and the S2 Sport fog replacements.
- Use switches or a control panel to group lights into usable zones (fog, mid‑range, long‑range) so you can customize output for any condition.
- Confirm that the behind‑grille kit and grille replacement kit are listed for 2025‑on 4Runner models, as grille shapes and mounting points may differ from earlier generations.
- For the S2 Sport fog replacement, make sure you have a non‑TRD Pro trim, since TRD Pro bumper and fog housings differ.
- Look for kits that include fused, relay‑based harnesses designed for lighting loads.
- Decide whether you want to tie into factory interior switch locations or use an aftermarket switch panel system.
- Route cabling carefully around the radiator, fans, and moving suspension components to avoid chafing.
- Behind‑grille and grille replacement kits often require removal of grille trim pieces and careful alignment of brackets.
- Fog light replacement is generally simpler since it uses factory mounting locations and connectors.
- Lumens: Higher total lumens generally mean more raw light output, but the beam pattern (spot, driving, wide‑cornering, or combo) determines how usable that light is.
- Color temperature: Neutral white around 5000–6000K is common on high‑end off‑road lights and enhances contrast on natural terrain.
- Look for IP‑rated housings for dust and water resistance.
- Opt for lights with hard‑coated, impact‑resistant lenses that can handle rock strikes and trail abuse.
- Pre‑bent brackets match the grille or bumper contours.
- Harness length and connectors are designed for the 4Runner’s engine bay and interior layout.
