Administrator
Administrator
Staff member
Jay
4Runner Key Advantages:
2025 2026 4runner 6th gen 2025 4Runner 6th Gen vs. Jeep Wrangler, Grand Cherokee & Ford Bronco -- Comparison Specs / 4Runner Advantages 2025 4runner 6th gen vs Ford Bronco
2025 2026 4runner 6th gen 2025 4Runner 6th Gen vs. Jeep Wrangler, Grand Cherokee & Ford Bronco -- Comparison Specs / 4Runner Advantages 2025 4runner 6th gen vs Jeep Wrangler
2025 2026 4runner 6th gen 2025 4Runner 6th Gen vs. Jeep Wrangler, Grand Cherokee & Ford Bronco -- Comparison Specs / 4Runner Advantages 2025 4runner 6th gen vs. Jeep Grand Cherok
4Runner Competitive Comparison Spec Charts:
CategoryToyota 4RunnerFord Bronco
Engines2 Engines:
- i-FORCE 2.4L Turbo
HP: 278
Torque: 317 lb.-ft.
- i-FORCE MAX 2.4L Turbo Hybrid EV
HP: up to 326
Torque: 465 lb.-ft.
3 Engines:
- 2.3L EcoBoost® I-4
HP: 300*
Torque: 325*
- 2.7L EcoBoost® V6
HP: 330*
Torque: 415*
- 3.0L EcoBoost® V6
HP: 418*
Torque: 440*
Drivetrains2WD
Part-time 4WD
Full-time 4WD
4WD Part-time selectable engagement
4WD with automatic on-demand engagement
Transmissions8-speed automatic7-speed manual
10-speed automatic
Max TowingUp to 6,000 lbs.4,500 lbs.
Rows2 (Available 3rd row)2
Cargo Volume (3rd row)89.7/47.2 cu.ft.
(88.8/46.3/9.0 cu.ft.)
83.0/38.3 cu.ft.
Available Suspension UpgradesAdaptive Variable Suspension (AVS), Bilstein® monotube remote reservoir shocks, 2.5-in. Old Man Emu with piggyback remote reservoirs, 2.5-in. FOX® internal bypass manual modal (QS3)High-Performance Off-Road Stability Suspension (HOSS) Systems (1.0–4.0)
MID DisplayAvailable 12.3-in. digital gauge clusterAvailable 12-in. digital instrument cluster
Multimedia DisplayAvailable 14-in.12-in. (one size only)
Audio SystemAvailable 14-speaker JBL® Premium Audio with JBL® Flex portable speakerAvailable 10-speaker Bang & Olufsen sound system
Available Off-Road Capabilities5 drive modes, Multi-Terrain Select, CRAWL control, Multi-Terrain Monitor, Hill Start Assist, high-mount low-profile air intake, Stabilizer Disconnect Mechanism, electronically controlled locking rear differential8 G.O.A.T. modes, Trail One-Pedal drive, Trail Control, Trail Turn Assist, Terrain Management System, Front Stabilizer Disconnect, front-locking and rear-locking differential
Available Convenience ItemsWireless Apple CarPlay® and Android Auto™, Power Up+Down Liftgate w/ kick sensor, pre-wired AUX switch DC panel, 2400W AC inverter, Digital Key, Smart Key System, Digital Rearview Mirror, front heated and ventilated premium leather-trimmed seats, rear outboard heated seats, Tow Tech Package, power running boards, power rear glass, standard Blind Spot Monitor with Rear Cross-Traffic AlertWireless Apple CarPlay® and Android Auto™, available wireless charging, remote start system, power + heated front seats
Standard SafetyTSS 3.0Available Ford Co-Pilot 360™
Note: Asterisks () denote “Requires premium fuel to achieve performance numbers.”
CategoryToyota 4RunnerJeep Wrangler
Engines2 Engines:
HP: 278
Torque: 317 lb.-ft.
HP: up to 326
Torque: 465 lb.-ft.
4 Engines:
- 3.6 Pentastar® V6
HP: 285
Torque: 260 lb.-ft.
- 2.0L I-4 Turbo
HP: 270
Torque: 295 lb.-ft.
- 6.4L HEMI® V8
HP: 470
Torque: 470 lb.-ft.
- 2.0L I-4 Turbo PHEV
HP: 375
Torque: 470 lb.-ft.
Drivetrains2WD
Part-time 4WD
Full-time 4WD
Command-Trac® Part-time 4WD
Rock-Trac® HD Part-time 4WD
Selec-Trac® Full-time 4WD
Transmissions8-speed automatic6-speed manual
8-speed automatic
Max TowingUp to 6,000 lbs.5,000 lbs.
72.4/31.7 cu.ft.
Available Suspension UpgradesAdaptive Variable Suspension (AVS), Bilstein® monotube remote reservoir shocks, 2.5-in. Old Man Emu with piggyback remote reservoirs, 2.5-in. FOX® internal bypass manual modal (QS3)N/A
MID DisplayAvailable 12.3-in. digital gauge clusterAvailable 7-in. digital cluster display
Multimedia DisplayAvailable 14-in.12.3-in. (one size only)
Audio SystemAvailable 14-speaker JBL® Premium Audio with JBL® Flex portable speakerAvailable 9-speaker audio system
Available Off-Road Capabilities5 drive modes, Multi-Terrain Select, CRAWL control, Multi-Terrain Monitor, Hill Start Assist, high-mount low-profile air intake, Stabilizer Disconnect Mechanism, electronically controlled locking rear differential35-in. tire package, underbody skid plates, high air intake, Electronic Sway Bar Disconnect, rock rails, heavy-duty full-float Dana® rear axle, Trails Off-road adventure guides, front and rear Tru-Lok® electronic locking differentials
Available Convenience ItemsWireless Apple CarPlay® and Android Auto™, Power Up+Down Liftgate w/ kick sensor, pre-wired AUX switch DC panel, 2400W AC inverter, Digital Key, Smart Key System, Digital Rearview Mirror, front heated and ventilated premium leather-trimmed seats, rear outboard heated seats, Tow Tech Package, power running boards, power rear glass, standard Blind Spot Monitor with Rear Cross-Traffic AlertApple CarPlay® and Android Auto™ compatibility, 4G LTE Wi-Fi, Remote Vehicle Start, forward collision alert, heated front seats, heated steering wheel
Standard SafetyTSS 3.0Brake assist, traction control, electronic stability control + anti-rollover, trailer sway damping
CategoryToyota 4RunnerJeep Grand Cherokee
Engines2 Engines:
HP: 278
Torque: 317 lb.-ft.
HP: up to 326
Torque: 465 lb.-ft.
3 Engines:
- 3.6 Pentastar® V6
HP: 293
Torque: 260 lb.-ft.
- 5.7L HEMI® V8
HP: 357
Torque: 390 lb.-ft.
HP: 375
Torque: 470 lb.-ft.
Drivetrains2WD
Part-time 4WD
Full-time 4WD
2WD
Quadra-Trac I® 4WD
Quadra-Trac II® 4WD
Transmissions8-speed automatic8-speed automatic
Max Towing6,000 lbs.7,200 lbs.
Rows2 (Available 3rd row)2 (Available 3rd row w/ L variant)
Cargo Volume (3rd Row)89.7/47.2 cu.ft.
70.8/37.7 cu.ft.
(84.6/46.9/17.2 cu.ft. L variant)
Available Suspension UpgradesAdaptive Variable Suspension (AVS), Bilstein® monotube remote reservoir shocks, 2.5-in. Old Man Emu with piggyback remote reservoirs, 2.5-in. FOX® internal bypass manual modal (QS3)Heavy-Duty Suspension, Rear Load-Leveling Suspension, Quadra-Lift® Air Suspension, Semi-Active Damping
MID DisplayAvailable 12.3-in. digital gauge cluster10.25-in. digital cluster display (one size only)
Multimedia DisplayAvailable 14-in.Available 10.1-in.
Audio SystemAvailable 14-speaker JBL® Premium Audio with JBL® Flex portable speakerAvailable 19-speaker McIntosh® Audio System
Available Off-Road Capabilities5 drive modes, Multi-Terrain Select, CRAWL control, Multi-Terrain Monitor, Hill Start Assist, high-mount, low-profile air intake, Stabilizer Disconnect Mechanism, electronically controlled locking rear differentialSelec-Terrain® Traction Management System, rear electronic limited slip differential, high air intakes and special water sealing combined with the Jeep® Quadra-Lift® Air Suspension System, front-axle disconnect
Available Convenience ItemsWireless Apple CarPlay® and Android Auto™, Power Up+Down Liftgate w/ kick sensor, pre-wired AUX switch DC panel, 2400W AC inverter, Digital Key, Smart Key System, Digital Rearview Mirror, front heated and ventilated premium leather-trimmed seats, rear outboard heated seats, Tow Tech Package, power running boards, power rear glass, standard Blind Spot Monitor with Rear Cross-Traffic AlertApple CarPlay® and Android Auto™ compatibility, 4G LTE Wi-Fi, Remote Vehicle Start, heated and ventilated front seats, heated rear seats, massage seats, heated steering wheel, power liftgate, 115V auxiliary power outlet, wireless charging pad, rear seat monitor, front passenger screen, 10-in. HUD, digital rearview mirror, hands-free active driving assist
Standard SafetyTSS 3.0ParkSense® Rear Park Assist, forward collision alert, adaptive cruise control, active lane management, blind spot monitoring, pedestrian/cyclist detection automatic emergency braking
E.T.
Orlando area
2025 4Runner Off-Road
Good comparison, I haven't seen anything put together like this with the key advantages between the 4Runner and the competition.
Did anyone actual cross shop against any of these 3 vehicles? I tire kicked the Bronco but end of the day didn't want to deal with Ford reliability vs. Toyota's.
Rusty Rattler
Rustyrattler
Bullhead City Az
2025 Toyota 4runner ORP
I drove that Jeep with the huge motor! It was not fun, felt really awkward, shifting was bad, braking was also bad, and corners at any speed was disappointing. So glad Iam a 4Runner owner.
  • Like
Reactions: JR1
I strongly considered the Bronco. I used to have a 1998 Ford Explorer, which I was very happy with (and had no problems). The Bronco is probably a bit more off-road capable, but in reality probably not much--especially if you know what you are doing. 4Runner is quieter, and I think a nicer vehicle to drive. Fuel economy, especially with the hybrid, is significantly better than the Bronco. Bronco is cool that you can remove roof panels and doors, but I figured I would rarely (if ever) use that feature. The rear door in the Bronco is less flexible--you have to open the bottom part first to open the window, and you do not get rain protection when open like the lift gate design. Spare tire on the back saves interior space, but makes it a lot more of a pain to deal with getting in the rear.
One thing I dislike in the 4Runner that really had me hesitating is the stupid way the back seats get out of the way--or don't. They can be rolled up behind the front seats, but that creates a large wall that obstructs most of the back doors as well as the rear ventilation (I did not get a model with a dual ventilation system--not sure if the rear ventilation is different with that). When the seats are flipped back down (but still folded) they are quite high. The hybrid battery raises the rear bed quite a bit--you get a bit of storage at the front and rear of that space, but I believe with the non-hybrid you get storage below (as well as the overall bed being lower). I have large dogs, and the 4Runner is definitely not as good for them as it is so high (but understandable, as a good off-road vehicle will be, by definition, higher).
I purchased one that happened to become available almost instantly that almost perfectly matched what I was looking for. It does not have the additional skid plates, but I can add those later. It also does not have the built-in brake controller which I would have liked (although it is possible I will not need it, in which case it will not matter). If found later that also adds a digital rear-view mirror which sounds great--but minor overall. Unfortunately I am told that brake controller package cannot be added later--and the manual says not to use a 3rd party controller! Not much choice if I do need one.
The 4Runner has better features by default (like all the newer safety features) that may be optional on the Bronco. Interestingly, the 4Runner was also less expensive, which I did not expect.
Overall I really like the 4Runner--I think neither would have been a bad choice.
