Ditch light mounting on hood
Maximus4R
Adam
Nashville
25 4R ORP
Hi All -
Hood mounted ditch lights are new to me - I’m used to wranglers and broncos where they mount to the a pillar base. I pulled the lower windshield trim and it looks like there’s a fender bolt I could bracket off of pretty easily. Am I just being weird and hood mounted ditch lights actually make more sense for some reason?
bakutheleo
2025 4Runner i-Force Max
Why do you not want to hood mount them? If you do otherwise you obviously need to make sure the hood does not interfere, but with hood mount by definition it will not be a problem. Also of course no modification required, and easy to install (well, I have some that I have yet to actually install, but it seems easy enough as you are just slipping it into existing bolts).
And yes, I understand I am not really answering your question!
Maximus4R
Maximus4R
Adam
Nashville
25 4R ORP
Actually that helps a ton as a sanity check! I was probably over complicating things with an a pillar mount. Thanks!
828findadventure
North Carolina
Tacoma & Tundra
hcubed
Scott
Northeastern California
I just installed these and I'm very happy with them, easy install. They also gave me a discount code.
Tacoma/4Runner Baja Designs Ditch Lights: https://lexlandgear.com/xhpgyy
Lexland 25% Discount Code: 828discount
https://lexlandgear.com/828findadvent...
That website is a bit confusing. At top, the choices lead me to believe that you are ordering a single light and bracket. Scroll down a bit and it has suggestions for adding raptor style lights and the a-pillar brackets.
Scroll down some more and you see "What's in the box:" which implies it is the full kit.
What did you specifically order to get the full kit?
828findadventure
North Carolina
Tacoma & Tundra
