jcaluya27
Julius
MO
4Runner SR5
Prepped the SR5 for the winter with Blasters Surface Shield. Did it myself with the kit below linked below. I’m no means an expert on application and I just followed “Repair Geeks” how to guide on apply it correctly.
Here my tips
- Prep correctly
- Take your time
- Wear personal protective equipment. Over spray will happen
- Have fun making your 4Runner last longer.
Surface Shield Kit
https://a.co/d/iZ2QyWW
How to application by RepairGeek
2025 2026 4runner 6th gen Surface Shield Rust Protectant Undercoating Applied (DIY) Surface Shield Rust Protectant Undercoating Applied 5
2025 2026 4runner 6th gen Surface Shield Rust Protectant Undercoating Applied (DIY) Surface Shield Rust Protectant Undercoating Applied 1
2025 2026 4runner 6th gen Surface Shield Rust Protectant Undercoating Applied (DIY) Surface Shield Rust Protectant Undercoating Applied 4
2025 2026 4runner 6th gen Surface Shield Rust Protectant Undercoating Applied (DIY) Surface Shield Rust Protectant Undercoating Applied 3
2025 2026 4runner 6th gen Surface Shield Rust Protectant Undercoating Applied (DIY) Surface Shield Rust Protectant Undercoating Applied 2
Kickin716
Scott
Buffalo NY
2025 Toyota 4Runner TRD Sport
Looks great! Did you pull down your spare tire first or just spray underneath it?
jcaluya27
jcaluya27
Julius
MO
4Runner SR5
Yes I took down the spare tire and pulled back the wheel well covers with the tires off. Job took about 3 hours total. And well worth it in my opinion.
sliver
Guy
Atlanta GA
That's great! I need to do this too, I was wondering if it was something I could do myself, now I know I'll give it a shot. Thanks!
jcaluya27
jcaluya27
Julius
MO
4Runner SR5
I was hesitant at first to do it myself also but after watching the video I linked above it gave me confidence to do it myself.
Just take your time and prep the car correctly and you will be fine.
BostonSR5
Nicely done. You're inspiring me to do the same. Did you lift the car in anyway, or just shimmy under the 4runner on your back?
jcaluya27
jcaluya27
Julius
MO
4Runner SR5
I used jacks so I can take the wheels off while I sprayed the wheel well and put the wheels back on. With the car on jacks and tires installed. Then I shimmied my way under car. Lol.
