What tire size for 20" wheels on 2025 4Runner Limited?
Bridge1821
Tom
SE Washington State
Lexus NX
I like the look of the bright wheels on the Limited trim. I understand they are 20" rims. What tire size will be on the 2025 Limited's 20" wheels? I'm hoping to find a compatible Bridgestone Blizzak for these stock rims.
dirtwheeler
For anyone else tripping across oldish this, this post provided some related info...
https://www.4runner6g.com/forum/thr...-bore-sizes-brands-2025-4runner-6th-gen.1962/
20" inch machine finished alloy wheels (+55mm offset)
(I tripped across this search for "Blizzak" since that will be one of my first mods... winter tires on a new set of wheels to swap out. At the time of my search, this was the only post that came up searching for Blizzak).
theo
theo
Blk4runner1960
How wide
dirtwheeler
You're asking how wide are the winter tires I'm considering? I'm still thinking about exactly what I want to do. For winter or daily driver tires, I try to keeping the geometry very close, if not the same, as the stock tires. I figure this is what was tested and optimal for most conditions (and will match what's on the door for PSI). So, this next set will likely be the stock size (including width) either with a true winter tire (Blizzak) or something more versatile (like KO3s). But I might also keep an alternate set to swap out (off-roading tires) on a different set of wheels (possibly 17" with a slightly wider stance).
gbennethum
george
reading pa
Does anyone know if you can put 18” wheels and tires on the limited that comes with 20”
Avendel
Max
Boston
Toyota 4Runner SR5
I'm running 275/55R20s on mine and they fit great with no rubbing. They feel better than the stock ones too, a bit more sidewall comfort without looking oversized. If anyone here ends up with a nail or sidewall damage in town, heavy truck tire repair Montreal helped me out quick once—they handle stuff like this even if it's a lighter truck or SUV.
