Removing 2nd row seats
Joimas
Joi
Ridgway, CO
2025 SR5 TRD off road 4runner
I love to use my 4Runners for camping because sleeping in the back was possible in all the old models. But with the new seat "tumblers," there is not enough room. So, I want to remove the seats and put a nice platform I can sleep on.
I am a woman with no mechanical skills. What would be the best option for me? I looked in the manual, but I can't find any directions for removing the seats.
Thanks!
timelapse
ATL
2025 ORP
I removed the rear seats in my 5th gen for added storage space. Planning to do the same when my 6th gen arrives. It should only require a ratchet and some metric sockets.
There's another thread somewhere on here showing the 6th gen rear seats removed. It's a helpful reference. They left the hinges on the floor. I plan to keep the seat attached to the hinges and remove it altogether, if possible. That's the only way to get a flat surface. If you plan to build some unique storage that needs to fold, leaving the hinges attached to the floor might offer some added design possibilities.
Old Spice
Bay Area
2025 4R TRD ORP
Yea @Kokorone posted pics of all seats - first row, second row and third row all removed from his 2025 4Runner
Here's the thread:
Seats removal (1st, 2nd, 3rd row) from 2025 4runner 6th gen - photos
https://www.4runner6g.com/forum/thr...rd-row-from-2025-4runner-6th-gen-photos.2325/
Photos from that thread
2025 2026 4runner 6th gen Removing 2nd row seats img_0964-
2025 2026 4runner 6th gen Removing 2nd row seats img_0965-
2025 2026 4runner 6th gen Removing 2nd row seats img_0963-
2025 2026 4runner 6th gen Removing 2nd row seats img_0966-
2025 2026 4runner 6th gen Removing 2nd row seats img_0968-
2025 2026 4runner 6th gen Removing 2nd row seats img_0967-
2025 2026 4runner 6th gen Removing 2nd row seats img_0969-
timetoclimb
'25 Everest OR
Can those attachment points/hinges that stick up also be removed to reach a flush surface?
timelapse
ATL
2025 ORP
I was disappointed that the rear floor doesn't provide easy access to the extra space below it on the non-hybrid 6th gens. The photos reveal there is some useful stash space below. Has anyone figured out an easier way to access it? Maybe someone will produce an aftermarket floor with hinged access.
My biggest complaint about the 6th gen is the lack of useful storage compared to the 5th gen. The 5th gen rear doors hold more than the 6th gen and you get multiple below floor storage access options.
zxrider11
DJ
West Michigan
Subaru
Go find an SR5 with the optional 3rd row seating.
With the 3rd row in the folded down position and the 2nd row seating also folded down - you get a pretty level sleeping platform similar to the Subaru Outback.
Joimas
Joi
Ridgway, CO
Yes, I just removed the entire assembly and it leaves you with a flush floor.
I’m having a nice platform fabricated. When it’s finished I’ll post some photos.
RobCMass
Milton, FL
2026 4Runner ORP Heritage Blue
I don't even want to know how much the cost would be to add a 3rd row seeing as the Insulation pad for the hood is over $500 from the dealer lol.
I am sure eventually someone will post a video of how to remove the 2nd row and brackets.
Kokorone
Gabriel
Laguna Hills, California
2025 4Runner SR5 4WD
The 2nd row seat brackets are pretty simple to remove. You just have to remove the seats which are 4 bolts each and then take off the remaining plastic shroud and it’s another 6 bolts for each side.
timelapse
ATL
2025 ORP
Glad it’s just as easy as the 5th gen. Did you have any issues after removing the wiring harness for the rear passenger detection? I’m hoping there isn’t an annoying error light on the dash. As it is, too many distracting notifications.
Kokorone
Gabriel
It does throw an error if you have the seats removed. Unfortunately while you can “clear it” with the main infotainment the error is not removable from the history log there.
I’d assume that if you put a resistor in series with the connector it’d suffice to shut up the warning
kj_bend
Kevin
Bend, OR
Do you have photos of your final product with the parts you had fabricated?
oregonalex
Portland, Oregon, USA
1998 4Runner SR5, 2025 4Runner TRD Off-Road
As described in the post linked below, I used a foam mat to cover the floor after removing seats. If you just have a carpet mat in the back, then thinner foam would be better. The pictures are of version 1 mat. The cordura turned out still too slick and things tended to slide on it too much. We replaced the top fabric panel with non-slip fabric bought at seattlefabrics.com. Works like a champ.
https://www.4runner6g.com/forum/threads/weight-of-rear-seats-150-lbs-in-trailhunter.7919/post-94849
Joimas
Joi
Ridgway, CO
I do! I had a fabricator build the frame so that it bolts down to where the seats were bolted down. It’s so stable- it doesn’t budge- even on back roads.
The platform itself is a birch plywood, and he made little wings to fill in the door space. Also there is a nice space underneath where the foot space was.
2025 2026 4runner 6th gen Removing 2nd row seats IMG_4233
2025 2026 4runner 6th gen Removing 2nd row seats IMG_4237
2025 2026 4runner 6th gen Removing 2nd row seats IMG_4234
2025 2026 4runner 6th gen Removing 2nd row seats IMG_4236
2025 2026 4runner 6th gen Removing 2nd row seats IMG_4238
2025 2026 4runner 6th gen Removing 2nd row seats IMG_4239
