Rough Country Ditch Lights wiring to Cali Raised OEM Switch?
DaddyCool13
Kai
San Diego, CA
2026 4Runner SR5
Hey all! Hope everyone is having a good weekend,
I just purchased the Rough Country 2” LED w/DLR pods, which comes with a rocker switch. However I’m looking to swap it out for the Cali Raised Dual Function light switch. Does anybody have experience doing this mod and can give me tips on how to wire the Cali raised switch to the pods? Would be greatly appreciated!
2025 4runner 6th gen Rough Country Ditch Lights wiring to Cali Raised OEM Switch? IMG_6949
2025 4runner 6th gen Rough Country Ditch Lights wiring to Cali Raised OEM Switch? IMG_6947
2025 4runner 6th gen Rough Country Ditch Lights wiring to Cali Raised OEM Switch? IMG_6948
DaMike13
Miguel
Beaverton, Oregon
2018 WRX STI
I have the rough country Ditch lights which I just installed the other day and used the factory aux switch for the flood. My ambers are powered by the ignition, so I don't use a switch for it. This is something you could do. Other wise read below
For Rough Country Ditch lights switch:
White --> Amber DRL
Blue ---> Flood light
Red ----> Positive (+)
Black ---> Ground (-)
Then you would need to figure out on Cali Raise switch what each color wire is for. Contact cali Raise for it.
Once you have it., cut the terminal ends off the RC ditch light switch and splice the wires into the correct color combo for the Cali Raised switch harness.
2025 4runner 6th gen Rough Country Ditch Lights wiring to Cali Raised OEM Switch? IMG_2083
DaddyCool13
DaddyCool13
Kai
San Diego, CA
2026 4Runner SR5
Thanks Mike! This is super helpful and I think points me in the right direction. I appreciate it! How do you like the lights?
DaMike13
Miguel
Beaverton, Oregon
2018 WRX STI
No problem, glad I can help!
The lights are great, the amber is not over powering and the flood lights work great! Haven't used in off road session yet but I'm sure they will perform great!
I need better brackets as it's touching the plastic slightly. Which brackets did you purchase?
DaddyCool13
DaddyCool13
Kai
San Diego, CA
2026 4Runner SR5
I actually sent these ones back because I wanted them to be hood mounted, so I bought the non-swivel lights that come with brackets. They say they’re for the 2024+ Tacomas, so I figured they’re likely to fit on the 4Runner, but I won’t know until I install them.
