Twin Motor On-Board Air Compressor| 100% Duty Cycle, 150 PSI — Wolfbox HyperFlow X
Wolfbox
Florent
Toyota 4runner
The Wolfbox HyperFlow X is a permanently mounted, twin-motor on-board air compressor designed for people who spend serious time outdoors. It combines fast inflation, long continuous runtime, and a durable design suited for dusty, muddy, and other demanding outdoor conditions.
Whether you're topping off tires, inflating rafts and pool floats, or blowing dust out of your gear before packing up camp, having a compressor that can keep running without frequent cooldowns can make the difference between a smooth pack-out and waiting around for the compressor to cool down.
Engineering and Technical Specifications
At the heart of the HyperFlow X is a 12V twin-motor, dual-cylinder architecture. With a true 100% duty cycle, the HyperFlow X can run continuously for over two hours at 40 PSI without requiring a cool-down break.
That capacity is useful for airing up multiple vehicles, running air tools, or handling multiple inflatables without having to stop between each one.
2025 2026 4runner 6th gen Twin Motor On-Board Air Compressor| 100% Duty Cycle, 150 PSI — Wolfbox HyperFlow X s&format=pjgp&height=1920&optimize=high&width=1920
Real-World Performance
The twin-motor design provides high-volume airflow, helping reduce inflation time when you're working with larger tires or multiple vehicles.
  • 37" tires: Inflates from 10 to 40 PSI in 3 minutes.
  • 35" tires: Engineered to inflate from 15 PSI to 35 PSI in under 2 minutes.
  • Beyond tires: The included 3-in-1 aluminum inflator gun can also be used as a blow gun for removing dust from vents, gear, and other equipment.
At 80 dB @ 40 PSI, the HyperFlow X runs noticeably quieter than traditional heavy-duty on-board compressors, making it easier to work without excessive noise or having to shout over the compressor.
Safety and Protection Architecture
The HyperFlow X uses a triple-layer active safety system:
  • Over-Current Protection – Helps protect against electrical overload.
  • Pressure Relief Valve – Helps prevent over-pressurization.
  • Smart Heat Control – If internal temperatures reach a critical limit, the system automatically pauses and auto-resets once it has cooled to a safe operating temperature.
The quick-connect chuck is protected by Patent No. 10,166,825 B2. A heat-resistant sleeve allows the hose to be safely detached immediately after heavy use, reducing the risk of touching a hot connection.
More below
Wolfbox
Wolfbox
Florent
Toyota 4runner
Installation
Estimated install time: 45–60 minutes.
The compressor features an integrated mounting base with pre-drilled M6 holes. The box includes four M6 bolts and four rubber vibration boots.
A vehicle-specific mounting bracket is not included. This bracket is the adapter plate that matches the compressor to your vehicle's factory mounting points.
The bracket shown in our installation video is an aftermarket F-150 bracket used for demonstration purposes. Similar brackets are available from aftermarket manufacturers, and many customers choose to fabricate a flat mounting plate based on their vehicle's available mounting points.
We're currently developing our own vehicle-specific mounting brackets, starting with the F-150.
The HyperFlow X is currently $50 OFF on the official Wolfbox Gears website, and it comes with a 3-year warranty.
👉 And here’s a little extra for you: use our exclusive code WBBESTGEAR at checkout through THIS LINK to get an additional $10 OFF!
828findadventure
Tacoma & Tundra
Installation
WOW, I really like that. I would love to install one in the 4Runner.
