Running Board mounting bolt size?
cpmartin1999
Atlanta
2025 4Runner SR5, 2024 Bronco OBX
Does anyone know the exact size (thread, length etc) of the OEM Running Board mounting bolts? i got some take offs with brackets but not the bolts?
horbit
DFW
I looked at mine and took a bolt off.
There are six bolts per side, two per bracket. 12mm hex head flange bolt. There are two dots on the head and the bolt has a captive washer, with a tapered end on the bolt.
I think you need 12x M8x30mm bolts with washers.
2025 4runner 6th gen Running Board mounting bolt size? IMG_2178
2025 4runner 6th gen Running Board mounting bolt size? IMG_2177
2025 4runner 6th gen Running Board mounting bolt size? IMG_2176
2025 4runner 6th gen Running Board mounting bolt size? IMG_2179
cpmartin1999
Atlanta
Thanks !! This is exactly what i needed, ill get some from hardware store, I really appreciate your help!!
