- Joined
- Apr 12, 2025
- Threads
- 4
- Messages
- 30
- Reaction score
- 36
- Location
- St Louis, MO
- Vehicle(s)
- 2025 4Runner
Oooooh that’s brilliant!If you open the liftgate and look at where the weather stripping meets the headliner in the middle, a couple inches inward on the headliner there is a round plastic plug (hard to see unless you're looking for it). There are actually 3 of these plastic plugs at the rear, top of the headliner.
What I'm hoping is, using the right tool for removing headliner plug clips, the plastic clip goes into some metal clip that you could also screw the right size sheet metal screw into. If that works out, the bracket holding the rear camera would be solidly mounted, but only with one screw. The 5th gen bracket I saw also had a bend in the bracket that hooks over the edge of the headliner, which would make it more stable.
Anyway, I'm not sure how or if any of this will work, but that's the direction I'm currently looking. I'm just hoping someone will be the guinea pig and buy that 5th gen bracket and report back. (this bracket from the OP's Etsy link: https://www.etsy.com/listing/1769081486/5th-gen-toyota-4runner-rear-dash-camera )
Thanks for the info! A couple questions:This does work from the 5th gen. I tried it out and it worked.
You could probably get a nut under the metal bracket that that clip goes into. I have some short m4 bolts ordered to try it out.
Note, those clips basically are impossible to pull out without breaking some of the tabs off. I’d make sure to have some on hand for a better fit.
