Wireless Trailer Brake Controller options
Gastan
Tacoma TRD Pro
As we now know, any 2025 4Runner 6th gen that doesn't come with Tech Tow Package from the factory will not have a wiring harness to plug the OEM Toyota trailer brake controller into.
For anyone who wants to hardwire in a physical aftermarket trailer brake controller into the dash, I posted instructions in this DIY thread.
For anyone considering a wireless trailer brake controller solution, these option were posted by a Tacoma owner (applies to 4Runner the same):
Not sure what the advantage is to a brake controller hardwired into the vehicle. I went to my dealer and they ripped the dash apart looking for a connector and they gave up and recommended the CURT 51180 Echo Wireless Trailer Brake Controler. I researched the echo and it does have some advantages and it’s low cost, but I did not like the idea of needing Location Services turned on, on my iPhone and the idea that the iPhone had to be running the app. That would take away my gps and music.​
I finally settled on the Tekonsha Prodigy RF Wireless Brake Controller. it more expensive but does not use your iPhone, but uses a simple controller plugged into the aux power connector. All brake controllers have a two or three degrees of freedom toque sensor that senses when you slow down. It uses the knowledge that you are braking to enable the trailer brakes. The amount of slow down force detected by the torque sensor and the gain setting of the controller controls the amount of braking the controller applies. Either of these wireless controllers can be easily moved from one vehicle to another unlike a hard wired controller. There are probably many other wireless controllers that would work as well as those I listed.​
jdgreen
MN
Ram 3500 diesel, 4Runner ORP
The TRD OR without Tow Tech I paid a deposit on is still "in transit". I'd decided on the Prodigy RF, but prefer the OEM package. Using Toyota "Search Inventory", I repeatedly looked out 500 miles for one equipped as I wanted. Over a month I found 4. My dealer was patient and tried without success on the first 3 to dealer trade. He was able to get the 4th one, perfectly equipped. It was built just a few days ago, so increases my wait time by a few weeks, but worth it to me.
CMill4Runner
Craig
CO
Did you install the Prodigy yet, any feedback you can share? I will be going this route as well the $9k upcharge to a premium for a brake controller doesn't work for me. I also had a '16 Tundra with Toyota's brake controller and it was so bad I had to add an aftermarket Tekonsha anyways.
jdgreen
MN
Here's a link to a You Tube video of TFLs ORP towing test using the Prodigy RF controller.
Surprise! The 2025 Toyota 4Runner Beat the Land Cruiser on the World's Toughest Towing Test!
CMill4Runner
Craig
CO
I watched this again and you're right, thanks for pointing that out. They don't go into much detail but at least I know it will work with the 4Runner now and that will probably be my choice! We're picking up our new trailer Friday so I will have some good 5th to 6th gen towing comparisons since we still have a month to wait for the '25.
s3lekta
M
ON, Canada
Any of you guys have some feedback on the Prodigy controller?
CMill4Runner
Craig
CO
I installed the Prodigy RF, is that the Prodigy you're asking about? If so, it works fine, and I like the separate brake controller module and not using my phone. It was fairly easy to install, drilling holes in my new camper frame to mount didn't excite me but it looks good once installed.
Dinosoar21
Jim
Northern Virginia
2025 Toyota 4Runner SR5
Great post, thanks...really saved me! Just trying to tow my race car, and surge brakes are not easy to come by, and my bare-bones SR5, of course, has no brake controller for ebrakes. I'll be dropping the extra coin for this setup.
Will posted any new feedback when I get it set up. Thanks again, Gastan!
