Steering Wheel Plastic Removal
DLubecki
Daniel
Mobile, AL
2026 Toyota 4Runner
How do I remove these two plastic covers behind the steering wheel? I removed the two screws behind the steering wheel for the top portion and I removed the bottom screw below the wheel for the bottom portion. I couldn't separate them by hand. I tried a pry tool, but I didn't pry to hard in case something was still connected. The pieces are loose, I just can't separate them.
2025 2026 4runner 6th gen Steering Wheel Plastic Removal Steering Wheel
ataveras64
Ariel
New York
2025 Toyota 4Runner SR5
The steering wheel covers can a little tricky at times to remove. I install a lot of remote starts and have removed these covers on hundreds of different vehicles and they're usually all the same. The way I would describe it is that you need to shimmy the bottom cover side to side while firmly pulling down on it until it unclips itself. You just need to double check and make sure that you did in fact remove all of the screws before doing that.
