Key on 12volt source
Striker53
Sean Ruth
Prince George
2025 off road Premium
Does anyone know where there might be a "keyed ignition point" in the rear area of a 2025 Off road premium HYBRID? Need a 12volt signal to turn on my dc-dc charger
mfoga
Socal
r4unner
Do you have the aux switches? If so on the low amp pigtail there is a wire that will work
HuskyDan
Dan
Santa Clarita area, CA
'25 TRD ORPH, '13 Wrangler Sahara JKU
Behind the right rear interior panel is a connector that the OEM Air Compressor that is standard on the TrailHunter trim comes with plugs into. One of the wires in that connector is hot when ignition is on.
