MandRonline
Colby
Burbank CA
Toyota 4Runner TRD Pro
*** Don’t Forget: Forum Members Receive a 10% DISCOUNT!!! Use Coupon Code 4Runner6G ***
Hey guys,
Upgrading your Toyota 4Runner's lighting is easy and affordable. Check out our M&R Automotive 2025+ Toyota 4Runner 40” Light Bar Pro.
2025 2026 4runner 6th gen M&R Automotive 2025+ Toyota 4Runner 40” Light Bar Pro Toyota 4Runner
Fits Toyota 4Runner 2025 2026
Trims: TRD Sport, TRD Sport Premium, TRD Off-Road, TRD Off-Road Premium, TRD Off-Road i-FORCE MAX, TRD Off-Road Premium i-FORCE MAX,
***If you are unsure what trim you have, please email picture for fitment confirmation.
  • Curved LED light bar PRO
  • Installs in front of the grille
  • Don't need to remove full grille, but all clips and bolts on top
  • No cutting or drilling required. The kit is a complete bolt on using factory openings and hardware.
  • Doesn't interfere with radiator air flow
DUAL COLOR: White with Amber DRL
Main White LED Light with Amber DRL (daytime running lights)
  • White LED -- Super bright and crisp white beam pattern. It will definitely provide you with enough light needed for all of your adventures.
  • Amber DRL -- amber DRL “daytime running lights” acts purely for aesthetics. Since it doesn’t give out much light, you can use this amber DRL feature on regular roads; it doesn't blind oncoming traffic.
DUAL COLOR: Yellow with Amber DRL
Main Yellow LED Light with Amber DRL (daytime running lights)
  • Yellow LED -- used in poor driving conditions such as dust, fog, snow and rain. It reflects through air particles much less than the white light, making it ideal for poor driving conditions.
**Please note** The yellow lens alters the look of the amber DRL, making it appear a little darker than with the white lens. Check the photos to see the difference.
  • Combo Pattern: combined spot and driving optics offer a balance between distance and width
  • Uses a TIR (Total Internal Reflection) lens, which is different from our regular slim light bar. The TIR lens collects all of the light from the LED and directly leads them to where you need, drastically reducing glare and improving total efficiency.
  • Higher light efficiency: brighter, longer irradiation distance
  • Housing is upgraded to 304 aluminum. The surface is UV polyester powder coated to protect against UV, salt water, corrosion, fading and scratch resistant.
  • Equipped with thermal management system that automatically adjusts the brightness output according to the external temperatures
👍Our light kits are for off-road use only.
For More information on the M&R Automotive 2025+ Toyota 4Runner 40” Light Bar Pro, Click HERE
