🏷️ 10% OFF Door Pillar Window Trim Kit for 4Runner | xipoqix
xipoqix_official
Jackie
China
Refresh the side profile of your 4Runner with our Door Pillar Window Trim Kit.
This set is designed to serve both a protective and aesthetic role. It define the window lines and cover the B-pillars, giving the exterior a more streamlined appearance. It also helps protect the original surface from potential scratches and everyday wear.
We offer two distinct finishes to match your style: Gloss Black for a subtle, factory-like integration, or Chrome Silver if you prefer a more eye-catching, custom look. Unlike common vinyl stickers that can peel over time, these trims are constructed from high-quality, rigid ABS material. This ensures a resilient, long-lasting upgrade that holds its shape.
This kit is designed specifically for the 2025-2026 Toyota 4Runner. Installation is straightforward with the pre-applied adhesive backing. Tip: Heat the adhesive and surface slightly with a hairdryer or heat gun for the best adhesion.
We’ve set up a special 10% OFF code just for you guys! If you want to give your 4Runner a fresh look, now is the good time to grab a set!
🏷Code: NY3HNW28​
📆Date: Feb. 25, 02:00-Mar. 10, 23:59 (PDT)​
Ulysses
2025 4Runner Hybrid
Make them in Bronze Oxide and I'd consider purchasing.
xipoqix_official
xipoqix_official
Jackie
China
Bronze Oxide isn't in our current production schedule. However, you might consider painting them yourself for a custom DIY project.
