Dash cam power
G19Tony
Tony
Las Vegas
Vehicles
2025 Ford Maverick XLT, 1994 Ford F150
I would like to see a power port above the rear view mirror for dash cam power. Some of the Grab vehicles I rode in when I was in Kuala Lumpur had them. I thought that was a fine idea.
GreatLakes
Well-Known Member
Michigan
Vehicles
F150 ‘16 supercab longbed! V8
As a DIYer vehicle, if Slate could at least run conduit, that might be nice. From the dash toward the doors, a good path back behind the seats and one up to the ceiling (& near rear view mirror)?
I learned about the value of conduit about five years after building my house. Cat5 ethernet to each room, but now that the drywall is up, Cat 5e / 6 /7 might be nice here or there. And plastic tubing is cheap!
slateya
Well-Known Member
Minnesota
Vehicles
Audi a4 200k miles, GMC 2500HD 350k miles, Moto Guzzi California
Conduit, molded channel, or just space within the removable interior and exterior panels to DIY wiring, cables. No pre-wiring needed.
Modern cars do not leave room inside the panels or make them removable to be able to add wiring in for any accessories. Slate could really differentiate themselves here.
Slate core mission is to economically produce a vehicle that does not have anything other than what is required to make it go and pass regulatory compliance safely.
Seeing lots of requests to pre-wire this and that misses Slate’s core mission.
Swinefuzz
Well-Known Member
San Diego, CA, USA
Vehicles
'98 Jeep Wrangler
Yes, I get your point. Everybody wants to request a feature on a product that's supposed to be intentionally lacking features to save the customer money...
However...
The doors are already wired for optional power window motors to be mounted and plugged in.
Also, the dash is wired to accept optional speakers to be mounted and plugged in.
Also, the dash is most likely wired to plug in an aftermarket stereo (confirmed double-DIN compatible).
Also, the dash is wired for optional tablets to be mounted and plugged in.
Also, the dash has USB ports ready for whatever the user wants to plug into them.
Also, the dash has a 12V port ready for...
Also, the frunk has another 12V port ready for...
Also, the truck reportedly has a V2L connection somewhere, probably at the tail end of the bed, for powering AC appliances, tools, charging another EV, etc...
It appears that the top center of the Slate Truck's front windshield has equipment mounted there, most likely the collision avoidance radar and/or pedestrian recognition and/or I don't know what else, like countless modern cars and trucks on the road, so there will already be wiring routed there. To include an extra line for a USB-C port to power a dashcam just makes sense and wouldn't cost much. If Slate Auto hasn't thought of it yet (I'm sure they have), I agree with the OP that it should be added. I use dashcams. Everyone should. They pay for themselves if you're involved in an accident. Dashcams are exploding in popularity. Every new car should be wired for easy dashcam install. Costs next to nothing. That's true added value.
cadblu
Well-Known Member
New York
Vehicles
Tesla
However...
I caught this screen shot on "Out of Spec Reviews" which shows pre-wiring for double DIN radios, also a set of USB connectors (suitable for dashcam power). Your assumption is validated.
Slate Auto Pickup Truck Dash cam power slate dash
If the rest of the truck is pre-wired like this, I am really looking forward to adding accessories.
Finally, Slate makes Plug and Play a reality!
SichuanHot
Well-Known Member
Vehicles
BMW E53 X5 3.0i
A main 12v accessory bus with fuses of your choosing below the passenger dash area, above the glove box section would be ideal for adding custom electronics. Prewiring going to the rearview mirror would add more complications than needs to be. I get annoyed dealing with the wiring for the rain sensing wipers in my 20 year old BMW as it is. Slate doesn't need that as a back to basics vehicle.
