TRD Pro Grille Lightbar Kit | Diode Dynamics
Diode Dynamics
St. Louis, Missouri
Website
www.diodedynamics.com
2024 Toyota 4Runner
2025 2026 4runner 6th gen TRD Pro Grille Lightbar Kit | Diode Dynamics hU5czwP
The TRD Pro Grille LED Light Bar Kit for the 2025+ 4Runner adds powerful auxiliary lighting with a clean, OEM-style appearance. These application-specific brackets have been CAD-designed to mount a 20-inch LED Light Bar behind the grille using factory mounting points. No cutting or drilling required! With higher light output, modern optics, and greater intensity than anything else on the market, the new Stage Series Lightbars are the most capable lightbars available today!
2025 2026 4runner 6th gen TRD Pro Grille Lightbar Kit | Diode Dynamics UB5Vp1
Designed for Performance. Each Stage Series Light Bar has been engineered from the ground up with the most modern optical, thermal, and circuit board technologies to provide more output than any other light bar on the market. Unlike reflectors, TIR optics capture and focus nearly all of the light output, shining it only where you need it, without glare or wasted light.
Thanks to copper circuit boards on the high-power models, thermal transfer materials, and optimized heatsinks, these lightbars effectively dissipate heat from the LED chips, allowing them to run at maximum power, producing serious light output.
2025 2026 4runner 6th gen TRD Pro Grille Lightbar Kit | Diode Dynamics IKjcBXP
Functional Beam Patterns. Each beam pattern has been fine-tuned for real-world conditions to perform even better than before.
The all-new Combo/Driving pattern has been engineered to blend distance and width into one balanced beam pattern. Everyone wants a great all-around light, and while other options on the market try to tackle this by combining two patterns, the resulting output is less than desirable–spot gives you a harsh hotspot, while a flood or wide pattern produces unwanted glare and wasted light. Our new Combo/Driving optic uses dozens of carefully-designed pillow optics to produce a blended, even output that measures 60x30 degrees and gives you throw downrange while still providing ample foreground illumination. It’s the ideal choice when you want one bar that can handle just about any situation, and it elevates the standard for what a Combo light should be.
SAE Driving is designed to supplement your high beams, but it's also great for general illumination, providing extra punch and distance ahead, without being a tight spot pattern. The SAE Driving pattern is a slightly broad-spot that balances reach and width with a spread of 20x12 degrees. If you’re looking to add extra distance and output to your setup, this is the perfect option.
2025 2026 4runner 6th gen TRD Pro Grille Lightbar Kit | Diode Dynamics LXAw3HS
Amber Backlight. All Stage Series LED Light Bars include an integrated amber backlight that fully illuminates the TIR optic, providing distinctive accent lighting and enhanced visibility when parked or stopped on the trail.
2025 2026 4runner 6th gen TRD Pro Grille Lightbar Kit | Diode Dynamics 9m8L374
White or Yellow. This Stealth LED Light Bar Kit is available in a cool white or selective yellow color. The white is a 6000K color temperature, which is a true cool white output, and matches most factory LED lighting. The selective yellow is a 3000K color temperature, great for high contrast in poor weather or a distinctive look on the road.
2025 2026 4runner 6th gen TRD Pro Grille Lightbar Kit | Diode Dynamics kDTE0xm
Choose Your Power Level. The SS20 Light Bar is available in two different power levels. The Sport model delivers impressive performance and value, while the Pro model provides a noticeable increase in total output and intensity for those who demand the highest level of performance.
2025 2026 4runner 6th gen TRD Pro Grille Lightbar Kit | Diode Dynamics oIpfeP5
In the Box:
  • One (1) TRD Pro Grille Light Bar Bracket Kit
  • One (1) SS20 Stage Series LED Light Bar
  • One (1) Wiring Harness
  • One (1) Front Camera Relocation Kit
  • Five (5) Zip Ties
  • Mounting Hardware
Warranty: Lifetime warranty
Return Policy: 30-day Return with no restocking fee
100% Satisfaction Guarantee
Fitment
NOTE: If you are installing this kit on a TRD Pro, you will need to use the included wiring harness with a new switch to control this light bar. The factory switch cannot be used to control this light bar.
Proven Reliability. Stage Series LED lighting has been extensively tested for long-term operation from -40 to 185 degrees F, along with vibration, moisture intrusion, and corrosion testing. All of these tests are completed to SAE standards, just like factory components. They've also been put to the test on-road by racers and enthusiasts alike.
Experience. After over a decade in business, Diode Dynamics is one of the most trusted names in automotive LED lighting. We directly manufacture and engineer our own products in the United States using globally sourced materials, allowing for higher quality and performance, with the newest and brightest LED technology. No matter what you're driving, we pride ourselves in offering only the best possible LED solutions. Please contact us if you'd like to discuss your lighting project!
Questions/Concerns:
Hours:
Monday-Friday 10 a.m. - 5 p.m.
Email: [email protected]
Phone: 314-205-3033
Maximus4R
Adam
Nashville
@Diode Dynamics - any idea on delivery timelines for these? I had an order with panda motorworks but ended up canceling after not being able to get timing updates. bummed about bc I ordered it on sale, oh well.
Dead Horse
Oklahoma
Yeah, every single light bar for this setup on the site said backordered.
Diode Dynamics
Diode Dynamics
St. Louis, Missouri
Website
2024 Toyota 4Runner
Thanks for the feedback, guys!
The all-new Stage Series Lightbars have been in extremely high demand since launch. Our in-house production team has been working around the clock to restock sizes ranging from 6" up to 50", across various colors and output levels.
If an order is placed directly through the Diode Dynamics website, even if the item is listed as backordered, it secures your spot in line for fulfillment. While the current estimate shows up to 8 weeks, that timeframe is a general forecast and is typically overestimated. In most cases, orders ship sooner than the displayed lead time.
We appreciate everyone’s patience and support while we work to get inventory back on the shelves.
Maximus4R
Adam
Nashville
Makes sense, thank you! Any chance you all have a forum discount? What about super discounted bundle if we get the ss6 fog an grille setup together? Can't blame a guy for trying , right?
Diode Dynamics
Diode Dynamics
St. Louis, Missouri
Website
2024 Toyota 4Runner
Unfortunately, due to our MRP policy with authorized dealers, we’re unable to offer forum-specific discounts, group buys, or bundled pricing.
That said, we do offer free shipping on orders over $200, and throughout the year we run a few select sales where certain products may be discounted (product availability varies).
Totally get the ask though — never hurts to try! We appreciate the interest and support!
df525
2025 4 runner sr5
It looks well thought out, even included zip ties / bolts for installation unlike some other brands. My only question would be feeding that switch through the firewall, might have to cut it off to swap with a toyota OEM switch.
