6GenChad
Tommy
San Diego
Evening,
I just wrapped up installing the Auxbeam RA60 switch panel on my 4runner. The install was very straight forward, maybe took me 1-3 hours including planning where I'd put the switch panel at, where the wires would go, how to make it clean and then ultimately installing it. I mounted my switch panel on the fuse box directly in front of the battery. I originally wanted to mount it on the other fuse box on the driver side but would've needed longer wires for all my connections. I didn't feel like doing all of that cause, I have no idea what I'm doing when it comes to wiring. I didn't drill into the fuse box just in case someone makes a bracket for the switch panel and the breaker down the road. For the time being, I just used 3M double sided tape to mount the panel and the breaker.
Running the wires was fairly easy after a couple of Youtube videos, I put a picture down below so you can get an idea of where the wires go. You can see that one positive wire runs from the battery to the breaker, and then to the switch panel. The negative runs from the switch panel to the battery.
The red wire is the fuse tap, which I connected it to the radio fuse in the fuse box. Now, If I had the extra length for all my wires, I would've gone to the other one and tapped into an ignition fuse but ultimately settled on the radio fuse. That fuse is always powered since it's used to save your Bluetooth settings, radio settings, car play, and your infotainment. I've had this sit overnight for more than 8 hours over multiple days and haven't had any issues yet.
2025 2026 4runner 6th gen Auxbeam Switch Panel & 3" Inch Pod Lights installed IMG_8711
2025 2026 4runner 6th gen Auxbeam Switch Panel & 3" Inch Pod Lights installed auxbeam
Also got the SXTH Element intake on this thing too, I LOVE IT!!
The black wire is the cord that actually powers the switch panel itself that's in the cab. I ran it along the cowling of the hood and then through the firewall on the driver side, up towards the air vent to the switch panel itself which sits in a 4Runner lifestyle mount just below the airvent. It replaces that grey trim piece, just have to take the clips off the old trim and transfer them over. It's easy to get the wire through the fire wall, just a pain in the ass to get the rubber off so you can stick it inside there, but after that, you'll be able to pull it straight out and up to the switch panel.
2025 2026 4runner 6th gen Auxbeam Switch Panel & 3" Inch Pod Lights installed IMG_8725
Here's the mount for the switch panel. I know some may ask why I didn't just get the switches and run the wiring there. The truth is because I got sent the Auxbeam switch panel and ditch lights for free. I wanted to do a switch panel anyways just for ease and peace of mind when I get other accessories down the road.
As for the lights, well I had my local offroad shop wire them up for me since I didn't want to mess it up. If you're in the San Diego area and need an offroad shop, Socal Suspension in El Cajon is my shop. Eric is a super cool guy, and has a rad truck (Vivian)
These 3' pod lights are surprisingly bright for how much they are. They are also mounted on Westcott Designs Ditch Bracket Lights Last I checked, you can snag a pair from amazon for $145 or on TikTok shop for just over $100. They ain't no Baja Designs but they'll be plenty enough for what I do.
Thanks Auxbeam again!
2025 2026 4runner 6th gen Auxbeam Switch Panel & 3" Inch Pod Lights installed IMG_8664
Overall, stoked with how everything came out.
If you have any questions, feel free to reach out
-T
2025 2026 4runner 6th gen Auxbeam Switch Panel & 3" Inch Pod Lights installed IMG_8667
NYNickET
Nick
South Carolina
2025 Toyota 4Runner ORP
what interior mounting panel did you use to mount the auxbeam 6 switch? looks real clean. . . .
toothpaste22
Ryan
Dallas
Hi, I just got around to install my RA80. All went well except the fuse selection. I used the 10A Ignition 1 (close to the 7.5A on the fuse B box like yours. I had error message popped up “Brake Override Malfunction” , it cleared as soon as I put back the original fuse.
Just curious how exactly did you set up the fuse tap, and which fuse did you select to tap?
Thanks in advance!
6GenChad
6GenChad
Tommy
San Diego
Thanks in advance!
I fused tapped into the radio fuse. It’s on the fuse box in front of the battery. Since it’s always on, my switch constantly has power. I did end up drilling the smallest hole I could in front of the fuse box to run the fuse tap wire. I can get a picture for you if needed
toothpaste22
Ryan
Dallas
Does that drain the battery if you have it constantly on like that?
6GenChad
6GenChad
Tommy
San Diego
I haven't had anything happen yet. It sits outside for more than 8 hours every night, just got to make sure you turn the swtich off so it's not lit up
toothpaste22
Ryan
Dallas
Right, it still has a tiny led. I dont think it’ll drain enough to cause trouble
