Raingler Nets
Ed
Eastsound WA
2018 TRD ORP
We are pleased to offer by request a full line of specifically designed gear for the 2025 - newer 4Runner! *Thank you to those whom reached out to contact us or offer to bring their 4Runner into the shop for fitting and development!
We have been making Raingler Nets since 1999 and always made in the USA. Please feel free to reach out for questions, suggestions or share your pictures of our Raingler Nets in your 4Runner!
6th gen 4Runner products
Seat back grab handles, barrier, ceiling attic, back window nets!
Gear for your Pup!
Very tough collars, and leashes that attach in your 4runner!
Back Window Net in Use (don’t mind the sad dog!)
2025-Newer-Toyota-4Runner-6th-Gen-N500-Behind-2nd-Row-Rear-Upper-Half-Barrier-Divider-Net-2.webp
2025-Newer-Toyota-4Runner-6th-Gen-N500-Behind-2nd-Row-Seat-To-Floor-Rear-Barrier-Divider-Net.webp
Henry
Henry
CT
For the full ceiling net, is there any support / anchor in this spot marked by the X ?
Raingler Nets
Raingler Nets
Ed
Eastsound WA
2018 TRD ORP
The main support for trghe ceiling attic net comes from the C & D pillars. We use beefy steel anchor plates. The OEM hook with it's spring clip wouldn't hold a lot of weight on it's own. Interestly enough the spring clips was support the passengler overhead grab handles on the previous generation. This back D ring connection to the OEM hook really just raises the ceiling net up out of the way for good rear window vision when unloaded or lightl, normally carried loads, jackets etc.
mattfuria
Cincinnati, OH
2025 Black 4Runner Limited - 1999 Jeep Wrangler TJ
Bought your nets for my '99 Wrangler and they have been great. Quality materials and fabrication. I do wish the friction clamps opened up a bit more to allow the material to pass through, but a needle nose pliers works just file.
These have been great for keeping the dogs contained when the Jeep top is off. Looking into the barrier net for sure on my 4Runner.
Raingler Nets
Raingler Nets
Ed
Eastsound WA
2018 TRD ORP
Appreciate that! I think if you get one for the Runner, you’ll like it more. We did update the cambuckles awhile back and if you feed the tapered strap end from the back, flat side, it should slide in and lock tight very easily.
