The overall ride is similar to stock, however it is a lot smoother over the very bumpy roads in and around Houston.I love it!!!
How is the plush/harshness of the ride vs the stock suspension?
Did you lift the rear, too?
How did you lift it?
If you didn’t make any adjustments prior to to installation it’s a 3/2 lift. Even the rear spring in the kit is a 2” lift spring.2025 Off-Road Premium
OME MT 64 shocks suspension 2.5" inch lift
35" inch Nitto Grappler tires
0 offset 17" inch Method 312 bronze wheels
They're adjustableI only see 3" lift kits for OME MT64 for the 6th gen. Wondering where you sourced your 2.5"?
I'm no expert. However, I run a similar setup. The front coil overs are height adjustable and the rear are not.
I have the same trim and color and was also thinking 2.5 in the front. Do you mind posting a direct side view photo?2025 Off-Road Premium
